Regassing Portable fridges
Submitted: Friday, Jan 16, 2004 at 09:03
ThreadID: 9789 Views:2786 Replies:3 FollowUps:4
Hi Guys,
Does any one know where l can get a Finch 3 way regassed in Melbourne, went a way over christmas and could not get it to get any colder then 8 degree's , it usually keeps our meat frozen, l would imagine it is in need for a service.
Regards & Safe Travels
Reply By: William - Friday, Jan 16, 2004 at 11:09
Phone Electrolux or Dometic in Melbourne who will be able to assist you.
It could be dust or a dirty burner. Run a tooth brush over the jet as there may be a carbon buildup on the burner. This will be easy to see when the burner is on, as the flame will not be a good looking blue colour.
AnswerID: 43213
Follow Up By: Jason - Friday, Jan 16, 2004 at 11:23
Is this possible when running on 240vlt.
Jason
FollowupID: 305531
Follow Up By: William - Friday, Jan 16, 2004 at 11:48
The element could have moved from its correct location, and again dust buildup can be an issue. If the coils and fins outside are dusty they cannot get rid of the heat. If you know what you are doing, take off the back panel and carefully wash them well with water and something like Cousins Morning Fresh which leaves no residual. Do not plug it in for a couple of days so you can ensure there is no water around the 240v parts.
If the Finch is old the element wire does age and increases the resistence which then does not give out sufficient heat. The element will normally have the resistance stamped on the ceramic and it can be checked with an ohm meter to see if it is currently the same.
FollowupID: 305536
Reply By: stillthinkinaboutit - Friday, Jan 16, 2004 at 12:05
Another thing worth trying is to turn the fridge off, shake the fridge very well, turn it upside down a few times, leave it upside down for a day or so. The solution(s) sometimes crystalize and the flow can be restricted causing poor cooling, the shaking and inversion can dislodge the obstructions. Also as you probably know, these fridges must be level to operate correctly.
Regards, Mark
AnswerID: 43221
Follow Up By: Jason - Friday, Jan 16, 2004 at 13:14
Hi Mark,
Yeah l,ve heard about the shaking thing as well might try that first before l go to the trouble of pulling the cover off and giving it a good clean.
FollowupID: 305543
Follow Up By: RayMc - Friday, Jan 16, 2004 at 21:55
My brother-in-law has one which was barely cool. A local refridge mech turned it upside down overnight and now it works a treat.
Ray
FollowupID: 305584
Reply By: jules15 - Friday, Jan 16, 2004 at 14:49
There is a firm in Clayton called "Caravan Refrigeration Service" ph:039574 1900 - try them.
AnswerID: 43234
