Jackeroo rattles ???
Submitted: Saturday, Jan 17, 2004 at 17:51
ozzy's
I own a 99 SE Jackaroo, it is a auto and has a developed a rattle that I can't find.
It only makes this noise when the car is cold and it goes away when it warms up.
I believe it may be from the auto transmission as when you start the car in
park or neutral, there is no rattle, but when any gear is selected the rattle starts.
I was wondering if any Jackeroo owners have had the same problem ?
Any feedback would be appreciated.
Reply By: Rick Blaine - Saturday, Jan 17, 2004 at 19:40
I did have a rattle in my Jack... but i traced it to loose components in the storage are for the jack & wheel brace.......I might add that my local Holden dealer couldnt find the rattle
43359
Follow Up By: ozzy's - Sunday, Jan 18, 2004 at 10:32
Thanks for the feedback, sounds like you and I both hate rattles.
305712
Reply By: Shaker - Saturday, Jan 17, 2004 at 20:07
Rattles from the exhaust system quite often go away, or appear as the vehicle warms up, the system grows in length as it gets hot.
43363
Follow Up By: Davoe - Sunday, Jan 18, 2004 at 02:10
Exaust would be a good place to start A cold motor usually runs rougher perhaps rattling the exaust especially as when you put it in gear it drops the revs a bit
305694
Follow Up By: ozzy's - Sunday, Jan 18, 2004 at 10:35
Thanks for
the tip, after having another look at it , it may be from the catalytic converter.
305713
Reply By: DP - Monday, Jan 19, 2004 at 21:55
Ozzy,
i have a Land Rover Discovery that had a very similar condition.
each morning when about 500m from home it developed a tapping noise in the motor, and went away after another 300m or so.
i traced this to the exhaust outlet manifold. the gasket was warn and the warming air escaping made a quick tapping noise.
on advise from a friend i took the car to an exhaust specialist who confirmed the problem and recitified by machining the manifold and replacing the gasket.
good luck.
43581
Follow Up By: ozzy's - Tuesday, Jan 20, 2004 at 18:46
Thanks for your help, the more I hear it would appear to be an exhaust problem.
305939
