cape trip with trailer
Submitted: Tuesday, Jan 20, 2004 at 14:57
Barry F
The family and I are going to the Cape in June/July with a trailer and we are thinking of a snorkle and extractors will it help or is a tarp across the front just as effective also we are getting a new trailer a Redback any feedback that might help would be much apreciated, our vehicle is a Ford Explorer, please no exploder jokes we've heard them all, touch wood, no problems as yet,
Reply By: flappan - Tuesday, Jan 20, 2004 at 15:56
What . . . No Exploder jokes . . . come on . . . Thats not fair.
Snorkle is always good for this type of thing. Its not only
water that its useful for. Allowing the air to be drawn from higher is good, because it can be slightly cooler and not as dirty.
Extractors on a modern vehicle is always fair questionable.
Actually, I think the biggest issue you will find with the Explorer is their questionable ground clearance. They are very ordinary. If you are undertaking this trip, especially towing a trailer (camper I assume), this is one area I would be seriously looking into.
43685
Reply By: Member - Des Lexik(SA) - Tuesday, Jan 20, 2004 at 16:01
Personally, I'd go the
snorkel and the tarp for the deeper crossings and a 20hp yamaha on the back of the trailer for the really deep crossings.
Only joking about the 20hp Yammy.
You'd need at least a 40hp.Dare to Lead not to Follow
43687
Reply By: Greg - Tuesday, Jan 20, 2004 at 16:36
Barry unless the wet is late
water depths will generally not require a tarp. I have extractors on my Pajero 3.5 petrol and definitely made a fair difference in torque and maybe 0.5 kpl in fuel (8 kpl average on road). Motor now puts out around 170kw. As far as trailers go it will need to be a very
well built off road trailer to handle the corrugations. A trailer will restrict you considerably on the telegraph track and some of the other remote tracks. I left my trailer home whilst some of my friends took theirs. I was much better off. A brand new
Kimberley camper had a shocker problem and a lesser koala trailer broke a spring. Clearance is certainly a big plus in the rough crossings. Good tyres and keep your pressures and road speed
well down.
43689
Reply By: Barry F - Tuesday, Jan 20, 2004 at 16:43
We have 16" rims with BF Goodrich's and polyairs for when the trailers on, it hasn't got the clearence of a cruiser but it's better than the standard explorer. I would be interested making it a little higher and what would be considered a good height without being to high the other half is only 5' and old sssshhhh, I didn't that.
43691
Follow Up By: flappan - Tuesday, Jan 20, 2004 at 16:57
2 inch /50 mm is the best and easiest amount of limit. Quite legal , and Insurance Co's have no probs with that amount of lift.
Its more the approach and departure angles of the explorer. They are ordinary. The big air dam on the front is useless offroad and gets pounded , and the rear has quite a long over hang (and the spare wheel as
well from memory). The
suspension lift will help, but it wont cure everything. Relocate the spare would be a good start.
305916
Follow Up By: Barry F - Wednesday, Jan 21, 2004 at 10:52
Thanks everyone for your advice, is this the best website or what, anyway i'm retracting my statement on ground clearence on my Frord .We have a 3.0 turbo diesel ST Patrol 2003 model at work, so I sat my ford next to it and proceeded to measure and compare and to suprise my ford has more clearence still might have to fix approach and depart angles. Bazzar.
306026
Reply By: Rod - Tuesday, Jan 20, 2004 at 17:37
Took camper trailer to the cape 2 years ago. Took the trailer up the OTL as far as
Twin Falls then used the bypass roads. Found the OTL much easier on everyone as the bypass roads were very badly corrugated. Saw two trailers on the bypass roads that had snapped either leaves or U-bolts. Going too fast and too heavily loaded was my guess.
North of
Twin Falls you encounter narrow bridges and
deep creek crossings on the OTL so we didn't venture go that way.
Cockatoo
Creek was probably the deepest
water we encountered (up to the bonnet inplaces). Had a
snorkel and simply loosened the belt driving the radiator fan so it would slip and drove through no probs without a blind.
43703
Reply By: Member - Bruce (San Diego) - Wednesday, Jan 21, 2004 at 02:19
Barry,
Yes it can be done .....But
We were up the Cape in Aug/Sept last year and did see one Explorer up there, it did make it to the top by the bypass road, and we saw it again at Bramwell.
It was in a pretty sorry state when it got back to Bramwell as they tried to come back and do a couple of
creek crossings on the Telegraph, as someone said earlier the angle of approach is very poor on the explorer and this one had gotten hung up front and rear and in the middle.
If you're going to tow a trailer up there with an Explorer at least tag up with a good friend in a Patrol or Landcruiser to help and stick to the bypass even with its corrugations.
Good luck
43766
Reply By: DARREN - Wednesday, Jan 21, 2004 at 12:58
I can't comment of the explorer but I towed a
well built box trailer with leaf springs up to the cape with a 3.85 explorer and all boat gear in/on it, the trailer did not give us any problems and did not restrict us from going anywhere we wanted, saw quite a few broken ones up there but some of them I must say I would not tow around town.
Very impressed by the guys in a L300 who brought their own welder to fix the trailer each time it broke. We went up the telegraph track incl. the section past
twin falls and found had no problems with it other than me having to be pulled up Cannibal
Creek exit.
My main advice towing a trailer with a wagon in particular is to make sure that you have a very good stone guard to avoid sand blasting the back of the car and smashing the rear window.
43789
Reply By: colin - Wednesday, Jan 21, 2004 at 17:09
Its always advisable at the end of each day travelling is to get under the trailer and tighten all the u-bolts and shackles as the vibration loosens every thing no matter how tight they are. If you have the space a spare spring doesnt go amiss, also spare pre packed bearings. Col
43816
