Steering Damper?
Submitted: Wednesday, Jan 21, 2004 at 15:51
Synergist
Howdy,
Just wondering if steering dampers have any real effect on controlling steering, i have a fj55 (no power steering) and the damper looks like the original.
If its worn would i know?
Whats their main role?
Thanks for any help!
Reply By: Member - Peter (York) - Wednesday, Jan 21, 2004 at 16:00
I replaced my dampener with a return to centre one from Tough dog ,it was
well worth it as it took the harsh spin out of the steering wheel if I hit a pot hole at speed , the overall steering performance was better with a new one fitted I had done 175000km at the time 99 GU Patrol 4.2 TD
York 4x4
43805
Reply By: Mark - Wednesday, Jan 21, 2004 at 16:50
I replaced the original one on my 80 series with an Old Man Emu one. It made one hell of a difference to wheel wobble/balance felt through the steering wheel. Wish I had fitted it years earlier.
As the 80 had power steering, there was no other noticeable effect. I never had the misfortune to have the wheel ripped from my hands when hitting an obstacle, but it is more likley the power steering rather than the dampener was responsible for stopping this.
Mark
43810
Reply By: howesy - Wednesday, Jan 21, 2004 at 17:41
It's main function is to endeavour in the control of bump steer and reduce the risk of the steering wheel being ripped violently from a loose grip. It doesn't however perform miracles.
43820
Follow Up By: Synergist - Wednesday, Jan 21, 2004 at 18:26
Is there any way of telling if it is worn out? Or is it a case of buy one and see there is a difference?
Cheers!
306081
Follow Up By: howesy - Wednesday, Jan 21, 2004 at 18:42
It's easy to get off, just remove it and check it for its resistance like you would a normal shock. The main diff between it and a shock is the centring ability and double action in both directions. Either way they are not that expensive if you think its the original just replace it and have peace of mind.
306082
Follow Up By: Synergist - Wednesday, Jan 21, 2004 at 18:59
Yeah, i think thats the best option.
Cheers mate!
306083
Follow Up By: Kev - (Cairns,QLD) - Wednesday, Jan 21, 2004 at 22:51
If you have a FJ55 & you think it has the original damper then just replace it, its
well & truly due for one.
Easy to replace & will cost about $100.
306130
Reply By: Paul - Thursday, Jan 22, 2004 at 00:34
Dampers usually get a flat spot in them, probably this is the position they do the most work. My cruiser hasn't got power steering and I didn't notice any difference when I put a new damper on. Admittedly it was the cheapest I could buy (ACDelco) but I couldn't imagine the resistance being anymore in an expensive one as too much damping resistance would make the steering difficult. Perhaps the others are dearer because they take longer to wear out or perhaps because of the pretty yellow paint?
Any way when I get a wheel stuck in a hole at times the wheel still spins fast enough to rip my thumbs off if I had em in the spokes.
Paul
43900
Follow Up By: pathfinder - Thursday, Jan 22, 2004 at 09:09
there is a huge difference in the resistance of a cheap vs more expensive (still only $100-200) steering damper...it's not just about pretty colours...
306144
Reply By: V8troopie - Thursday, Jan 22, 2004 at 02:07
I tell you what you don't want to happen, as happened to me, and that is the eye on the end of the (Toyota) steering damper breaking off. Its very very scary. Luckily the car ( troopcarrier) was travelling slow at the time. Its like the front
wheels assumed they cannot make up their mind which way to point and so rapidly and violently change direction. I only just managed to pull over to the road side on a quiet suburban street. Had that happened at freeway speeds I'd been history.
After stopping I quickly realised what had happened and managed to drive the few kilometers to the ARB
shop very slowly. Any speed over 20k and she'd start bucking. I now realise that steering dampers play a vital role on big 4WD's :-)
Klaus
43910
Reply By: Roachie - Friday, Jan 23, 2004 at 13:53
I put a new 4-Ways Return To Centre damper on my 3 year old T/D Patrol a couple of months ago. It certainly took away a little shimmy I had in the steering at about 80kph. With the spring in place, before I fitted it to the truck, I couldn't manually push or pull it from it's resting location. The Nissan one I took off still felt like it has a bit of resistence, but I could push it in and out reasonably easily.
I very pleased with the 4-Ways unit.
Roachie
44108
