Mobile Phone in Landcruiser
Submitted: Wednesday, Jan 21, 2004 at 19:40
ThreadID: 9921 Views:1780 Replies:1 FollowUps:0
I have a 1999 GXL Landcruiser with standard Toyota CD/Radio/Tape system.
I'm trying to install a Seimens car kit and need to know which wire on the rear of the radio is used to auto mute the radio when a call is received or made.
Any help please?
Reply By: Member - Bob L - Wednesday, Jan 21, 2004 at 21:09
No guarantee this radio has a mute function but check for a purple wire which is possibly terminated.
If found test by grounding to earth. If this is ok car kit mute must provide the ground. If it shows positive volts you will have to use a relay to achieve same.
I have seen a relay used to cut power (acc) to radio but don,t do this to the permanent supply as you will end up jamming the cd /tape functions or set off security code.
Hope this helps
Bob L
AnswerID: 43846
