200 series key problem
Submitted: Friday, Dec 21, 2012 at 09:19
pepper2
My mate has a 200 series cruiser,he has found that he cannot secure a spare key on the vehicle as when the key is within a specified distance to the vehicle the vehicle unlocks...Toyota cannot provide a solution,has anyone worked out how to carry a spare key on these vehicles????
Reply By: SuperGrover - Friday, Dec 21, 2012 at 10:25
The car detects the electronic fob which prevents you from locking your keys in the car. The electronic fob holds an emergency key to use when the electronic fob battery goes flat. Just remove the emergency key from the fob in your spare set and place that on the vehicle this will not prevent the car from locking but will give you or anyone else who has it access to your vehicle.
500803
Follow Up By: Wayne (NSW) - Friday, Dec 21, 2012 at 10:56
SuperGrover,
That sounds like a great idea, but will you still need the fob close to start the vehicle?
Has the vehicle got a slot for the emergency key to start the vehicle?
The base model has kept the old fashion key to start the vehicle.
Wayne
776838
Follow Up By: TerraFirma - Friday, Dec 21, 2012 at 11:31
Yes it has a slot and yes you can. Toyota would also know this.
776844
Follow Up By: SuperGrover - Friday, Dec 21, 2012 at 12:40
Yes you are correct. You do need to have the key fob to start my 2010 200 series. I know that when the battery is flat in the fob you must hold it against the start button to start the vehicle. So both suggestions with the FOB hidden on the inside either remove the battery or have one with a flat battery that you can hold against the start button.
776848
Reply By: Allan B (Member, SunCoast) - Friday, Dec 21, 2012 at 10:46
Try wrapping the key in several layers of aluminium foil and place it in a small metal box. That may attenuate the wireless transmission to and from the key.
500805
Reply By: Member - Phil G (SA) - Friday, Dec 21, 2012 at 11:41
Just remove the battery from the fob and store them separately.
500807
Follow Up By: Member - Phil G (SA) - Friday, Dec 21, 2012 at 11:45
Or I can elaborate on my plan - to remove the key from the fob and hide it somewhere on the outside of the vehicle - so you can get into the vehicle. Hide a spare fob inside vehicle with the battery removed. I've only had the vehicle for a few weeks, but that was my plan! Also the fob will work without a battery provided you hold it right next to the start button.
776845
Follow Up By: Member - Boobook - Saturday, Dec 22, 2012 at 06:31
That;s how I have done it for 5 years Phil. Works like a charm.
776891
Follow Up By: Member - Phil G (SA) - Saturday, Dec 22, 2012 at 17:34
ThanksTony,
Thats reassuring.
I have a great fear of locking myself out of the 200series in the middle of nowhere :-)
776923
Follow Up By: Member - Boobook - Saturday, Dec 22, 2012 at 17:37
Glad to help anyone with a 200 and a Tvan. You must be a true gentleman.
776924
Reply By: Member - Rosco from way back - Friday, Dec 21, 2012 at 14:17
Can't you simply use a plain key to open the door?
500813
Follow Up By: Member - Boobook - Saturday, Dec 22, 2012 at 19:09
Yep if that's what you want.
776927
Reply By: lostinwauchope - Saturday, Dec 22, 2012 at 02:42
quote [ My mate has a 200 series cruiser,he has found that he cannot secure a spare key on the vehicle.]
If the vehicle is stolen there is no insurance, spare keys cannot be stored in or on the vehicle be careful.
merry xmas . Ron
500851
Reply By: Tim - Saturday, Dec 22, 2012 at 04:23
I had similar issues with a new prado.
If they are the same, you can remove the key from the fob, store the key underneath somewhere and put the fob in the car. You then must use the lock/unlock buttons on the other fob to lock and unlock your car. You won't be able to lock it by using the magic buttons on the doors as they won't let you lock a fob in the car.
Tim
500852
