Towbar <span class="highlight">wiring</span> on bt50
Submitted: Tuesday, Jan 08, 2013 at 22:27
Scotty
Just had a Hayman reese towbar fitted and I thought it had a plug and play
wiring loom / harness but when I looked underneath they have used cable splices, any of you had one fitted?
Reply By: Millsy999 - Wednesday, Jan 09, 2013 at 06:12
It should definately have a
wiring loom. Nothing should be patched directly into the rear light
wiring. I would be taking it back to the installer before plugging anything into it.
502087
Follow Up By: Scotty - Wednesday, Jan 09, 2013 at 09:10
Thanks Millsy,
But you misunderstood the post, the rear
wiring loom is where you get your feeds and trigger feeds from, where else? The point I was asking has anyone had a towbar fitted recently and was it plug and play or was it spliced as I,m sure I read in a magazine that it is all plug and play connections.
I had a bullbar and canopy fitted recently and they were both plug and play and not spliced.
778448
