Sunday, Jan 05, 2020 at 12:31
Yes Peter, I would agree wholeheartedly that corrugations are a killer for batteries, as is heat. The engine bay is the worst place to locate a battery and a few auto makers have engineered alternative locations from time to time but most opt for the convenient spot.
A problem in engineering (and elsewhere) is that the ideals of physics do not always prevail due to all sorts of reasons. That is why it it is unwise to proclaim that it "will happen" or it "won't happen". All I can point to is what an "authority" or manufacturer may proclaim and add my own experiences.
Which is why you have experienced one thing and I the other. And I certainly do not dispute your experiences or their validity.
I also have destroyed several AGM's when positioned under the bonnet and after repositioning to the cabin and adding dc-dc charging I am celebrating their performance. Maybe their distance from the alternator and the accompanying cable resistance would limit the charge current to a non-destructing value but I put in dc-dc charging anyway so have not experienced the former. Maybe a bit of cable resistance is benefitting your auxiliary batteries. And if your cranking battery is not in the engine bay then it would have a longer cable from the alternator which may be of benefit. See the "maybe's" creeping into this?
I do observe that the current from my alternator to the cranking battery sometimes is as high as 40A initially after an engine start but soon drops to a lower value to settle at just a few Amps for a while, then zero until the next start. It does not take more than a few minutes to replenish the battery. The auxiliary battery ammeter on the other hand sits right at the 40A maximum of the charger for a couple of driving hours until settling down. The 40A is shared between two paralleled AGM batteries so is within their specifications. In truth, I have not ascertained their balance but I assume it is reasonable as they are identical in all respects. Anyway, it works which is as you say, "practice not theory".
It just goes to show that there is more than "one way". And I am a great believer in "what works, works".
If I was starting afresh I would be tempted to use a single lithium bank for everything including cranking and carry a little lithium jump-starter for emergency. Ahh, dreams and experiments!
904182
