the longranger 84 litre aux fuel tank FJ cruiser
Submitted: Wednesday, May 19, 2021 at 17:12
Murray M7
Hi anyone else had problems with their aux fuel tank? I had the transfer pump fail after 2 years and approx 10 tank tansfers. Today when servicing vehicle for upcoming trip went to change the aux tank filter and noticed that the fuel hoses are badly perished the tank is only 2 1/2 years old
Reply By: RMD - Wednesday, May 19, 2021 at 18:14
Murray
It seems you don't have a problem with the tank at all, only the pump and hoses. It appears the quality of the hoses is rubbish and pointsvto dhirt cuts by installer. Maybe the pump has a gutful of particle crap from the poor hoses. Any pump should last a very long time. A normal fuel injection pump runs constantly and is ok for use in aux tank transfer situations. I use one from a crummydore for aux tank to main tank, manually controlled.
636469
Follow Up By: Murray M7 - Wednesday, May 19, 2021 at 18:49
So I gather by your reply you dont have any issues with your aux tank? I was asking if anyone else has had similar issues as me. You apparantly have not. I would of thought when you pay almost $2000 for an aux tank from ARB that the transfer pump would last longer than 2 years transfering at most 800 litres and the hoses would last longer than 2 1/2 years. Further more I am a qualified mechanic and did the install myself. One thing I do agree with you about is that the hoses are rubbish. So if anyone else out there has a Long
ranger tank
check your hoses
914387
Follow Up By: RMD - Wednesday, May 19, 2021 at 19:27
Why did you, as a qualified mechanic fit dodgy hose?
What markings are on the hose, is it really petrol fuel compatible? Have you fronted ARB with the obvious lack of quality of the components? Most reputable hose lasts
well. Did they look kosher at the outset? Have you determined the issue with the pump? Particle obstruction? pump element failure? Electrical motor fault? It should be obvious. What brand of pump? Any info you reveal will help others!
914389
Follow Up By: Murray M7 - Wednesday, May 19, 2021 at 20:04
Hey RMD whats with the questions? did you read my post? I am asking for other peoples experiances not questions as you are asking. You have all the questions but as yet no answers. How many people do you think have had ARB install an aux fuel tank? I am asking if anyone has had similar issues. So if you have no answers to my questions PLEASE keeps your questions/accusations to you self
914390
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, May 19, 2021 at 20:51
Take it up with ARB, the warrany may only be 12 months but you have consumer rights even if you did install it yourself. 2 years or more warranty is reasonable for a $2000 purchase. Maybe you have already done that. Regards Michael
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
914392
Follow Up By: RMD - Wednesday, May 19, 2021 at 20:53
I am a bit puzzled with all this. If others have similar problems, what then? How does that help you. I cannot work out what is trying to be achieved. I suggested some situations which may be possible.to assist you. I am also an Automotive person and find the post puzzling. Are you alerting others, requiring help to solve your issue, what exactly?
914393
Follow Up By: RMD - Friday, May 21, 2021 at 11:05
Murray
Just for clarification.
You said you have trouble with your aux tank. You Don't! It is with other components. IF 543 others have had problems too, not with the tank but components associated with the tank, does it change your situation?
I asked perfectly normal analytical, diagnostic questions to try and solve the issue you have, I presume you have that diagnostic ability as a mechanic. Answers to those questions will reveal faults or quality of the gear supplied. Therefore, you will understand WHY questions were asked. Without a preparedness to answer to those questions, no one can help you.
914419
Follow Up By: Murray M7 - Friday, May 21, 2021 at 13:30
RMD all I wanted to know was if anyone else had has a similar issue with the hoses, the main fuel transfer line is fine and is EFI rated hose SAE 30R9 which is rated for basically any fuel type. The reason I am asking is because the fuel filler tube had to be cut and modified to a twin filler it is these hoses and the new breather hose which is the issue. I can use off the shelf breather hose but the hoses for the modified twin filler tube have pre formed bends. So I don't really want to replace the filler hose with a similar hose if it is going to break down in a 2 to 3 years
914423
Reply By: MickO - Wednesday, May 19, 2021 at 20:55
Murray I had issues but more around the structural integrity of a replacement main tank for my Patrol. They had not gusseted or reinforced top and bottom edges causing them to crack and weep. More disappointing was ARB, 's unwillingness to stand by their product (supplied and fitted by them in Bayswater). They just supply and fit. "You'd need to take it up with the manufacturer" they said. Buyer beware!
Cheers, Mick.
636473
Follow Up By: Allan B (Sunshine Coast) - Wednesday, May 19, 2021 at 21:37
I would hope Mick, that you pointed out to ARB that Consumer Law
places the responsibility initially with the supplier, in your case ARB.
What did you say when they told you "buyer beware" and to "take it up with the manufacturer" ?
And what resolution was there to the tank faults ?
914396
Follow Up By: Gramps - Wednesday, May 19, 2021 at 21:56
Mick O,
As per Allan's reply above, you bought the product from ARB not Longranger. ARB are responsible for any redress required.
914397
Follow Up By: MickO - Thursday, May 20, 2021 at 07:38
Gents, "Buyer beware" is my comment not theirs so sorry for any confusion there. Tank was 18 months out of warrantee.
After much towing and froing and some robust conversation they offered to remove the tank at my expense and send it to Qld. Reinstal would also be at my expense and car off road for 2-3 weeks.
In frustration, I took the car to Brown Davis who pulled it out repaired and reinforced it with pakman plates for around $300 if memory serves me correctly.
Several other issues
914398
Follow Up By: Member - John - Thursday, May 20, 2021 at 07:51
MickO, just a quick question please mate, "Pakman" plates? As Pauline would say, please explain? TIA.
914400
Follow Up By: MickO - Thursday, May 20, 2021 at 08:05
Couldn't think of a better way to describe them
John. They are a circular plate with a piece cut out o match the protruding edge of the tank. Reinforces the two pieces rather than rely on the weld alone. Resembles a pacman from the old video game.
Hope the highly detailed and skilled engineering drawing (NOT) gives you an idea.
Pacman
914401
Follow Up By: RMD - Thursday, May 20, 2021 at 10:08
Mick
Having a fuel tank with an internal step return like that will cause high stress right at that internal corner point. I am surprised the manufacturer doesn't know. The failure rate is probably low and then most of claims can be avoided/stalled anyway. Maybe they never looked at reinforcing plates on
farm and earthmoving machinery.
914407
Follow Up By: Member - John - Thursday, May 20, 2021 at 10:23
MickO, thanks, understand exactly now, good name, LOL
914409
Follow Up By: Life Member - Duncan W (WA) - Friday, May 21, 2021 at 10:47
Mick I'm on my 4th Longranger tank and each of the previous 3 were replaced under warranty. 1st sprung a leak in the body of the tank on it's 2nd fill. I think in this case the internal baffles may have been flexing and caused a
puncture a bit like bending a tin can backwards and forwards. Next the following year again in the body of the tank and the last one the mounting angle web weld fractured. The last one fuel poured out (typically after I had just filled it at Mt Barnett Stn and I had to return to
Perth from the GRR earlier than expected. In each case Longranger replaced my tank under warranty and the company I'd bought them from replaced them free of charge. We hope we have now solved the problem by putting rubber bushes between the mounting points and the tank mounting angles so as to allow a bit of flex and it seems to have worked
Fingers crossed no more problems.
To date I haven't had any issues with the transfer pump or hoses or filters.
914418
Follow Up By: RMD - Friday, May 21, 2021 at 18:49
Duncan
Good to see you mention the failure with the mounting systems. Many seem to not understamd a 4 wd during offroad stuff flexes and twists the chassis quite a bit. The tanks don't like that and having flex/padded mounts is probably essential for life of the tank.
914425
Reply By: Allan B (Sunshine Coast) - Wednesday, May 19, 2021 at 21:44
Hi Murray,
No problems with my Long
Ranger 180 litre replacement rear tank on the Troopy which did a couple of hundred thousand k's over some of the roughest roads in Australia. It was supplied and fitted by ARB
Maroochydore.
Mind you, the hoses used were possibly the original ones from the 2002 build.
636474
Reply By: Member - McLaren3030 - Thursday, May 20, 2021 at 07:30
Hi Murray,
Similar experience to Allan, my 100 Series Landcruiser had a 180 Ltr Longranger tank fitted for
well over 200,000 kms without any problems,
Gibb River Road, Tanami Track. 76 Series Wagon same story, 90,000 kms. Both fitted by ARB.
Perhaps the tank is not the issue. If as you have mentioned, you did the install, I can understand ARB’s reluctance to accept responsibility.
636478
Reply By: 9900Eagle - Thursday, May 20, 2021 at 08:45
If the hose is red it is possibility ortac and even though it has a habit of cracking the outer sheath it is a quality product. I have had no problems with my long
ranger tank over 9 years
636480
Reply By: 2517. - Thursday, May 20, 2021 at 12:44
I have fitted 3 Long ranges tanks over the years, never had a problem with hoses but the mounting brackets were never right ,close but one bracket always need adjustment.
636487
