How to tell if diff is LSD?
Submitted: Tuesday, Jan 04, 2005 at 01:27
Member - Haldo (Sydney)
I have a 1994 Toyota Landcruiser turbo diesel auto. Trying to find out if the diff's are of the Limited Slip variety. Checked the compliance plates but little info there. The owners manual says diddly squat.
Any ideas what to look for and where?
In the process of changing fluids and the front and rear diff oils are next on the list (if I can prise the vehicle out of SWMBO's hands).
Funny thing, since 'we' (spelt yours truly) bought the cruiser someone else has taken to leaving her Calais at home and taking my baby.
How do I get it back?
Anyone want to buy a little used Calais?
Help.......
Reply By: Member- Rox (WA) - Tuesday, Jan 04, 2005 at 01:34
Should have a sticker on the rear dif if its lsd.
91209
Reply By: Tim HJ61 - Tuesday, Jan 04, 2005 at 02:03
Haldo,
Don't want the Calais, thanks.
Two ways to
check is dif is LSD if it's not written on housing.
#1. Jack up one wheel and see if you can turn it easily. If it is really hard to turn (and you've not left the handbrake on!!) then you've got an LSD. An open dif should turn without apparent restriction with one wheel up and one wheel on ground.
#2. Just for fun.
Park cruiser pointing at side of Calais. Jack up one rear wheel. Start Cruiser and engage 2nd gear. Drop clutch with heaps of revs. If Calais lurches to one side and appears significantly damaged, you've got an LSD. If you get just lot's of noise, you've not moved and neighbours looking at you shaking their heads, you've probably not got one.
I'd suggest #1 first..... :-)
and NEVER #2
Ever helpful
Tim
91213
Follow Up By: Member - Roachie (SA) - Tuesday, Jan 04, 2005 at 10:52
RAOFLMAO.............................
349801
Follow Up By: Moneypit - Tuesday, Jan 04, 2005 at 22:23
Bloody Funny. Nearly cried.
Dave
349900
Follow Up By: Bonz (Vic) - Thursday, Jan 27, 2005 at 17:54
hahahah Try 2 first
GET PHOTO's
If it turns out you dont have a LSD, let me know and we can repaeat the
test with my Patrol :)
353987
Reply By: Member - Ed. C.- Tuesday, Jan 04, 2005 at 02:17
G'day Haldo,
Try this...
Jack both wheels off the ground (handbrake off, trans in neutral)...
Rotate one (either) wheel by hand.. with an open diff, other wheel will rotate in opposite direction to the one you are turning...
If it's an LSD (and it's working), both wheels will rotate in the same direction...
Regards, Ed. C.
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
91214
Reply By: Kiwi Ray - Tuesday, Jan 04, 2005 at 07:19
Take the long number of the ID plate ( may start HDJ or similar ) to a good Toyota dealer and ask for the build sheets.
They can access this from there computors.
This info is world wide on the Toyota network
Ray
91216
Reply By: Member - Haldo (Sydney) - Tuesday, Jan 04, 2005 at 10:55
Great service, as usual.
Many thanks for the help.
When SWMBO comes
home I'll see if I can make use of the little daylight I'll have left, to try these ideas but I don't think option #2 will go down too
well, although it's worth a try.
91241
Reply By: Member - Chrispy (NSW) - Tuesday, Jan 04, 2005 at 11:28
Another way is to get the car onto some grass or gravel, and do tight doughnuts. Look out the window (when turning right) and see if the inner rear wheel is scrubbing - i.e. it is driving at nearly the same speed as the outer wheel and slipping. If it is, you probably have LSD.
91250
Reply By: Member - Phil G (SA) - Tuesday, Jan 04, 2005 at 12:47
I thought they all had LSDs by 1994. Doesn't matter anyway. Most workshops use LS90 oil in the diffs whether limited slip or not. LS90 in an open diff is fine.
91266
Follow Up By: Member - Haldo (Sydney) - Tuesday, Jan 04, 2005 at 13:51
Thanks to all who replied.
When my better half comes
home I will try what you said.
Very tempted to use Option #2.
Thanks Phil for the info on what lubricant to use.
Not long now, til gold watch day, then I am my own man.
349826
Reply By: Member - Davoe (WA) - Tuesday, Jan 04, 2005 at 14:21
when I first went to service my camper I drove past a tyre joint and they jacked up the rear end I spun one wheel and the other rotated in to oppisite direction so no lsd
91278
Reply By: Member - Jeff M (WA) - Tuesday, Jan 04, 2005 at 15:02
Find that irritating neighbour that has a bowling green for a lawn and every night on your way
home they are standing in the front yard hand watering it for hours on end (because there is
water restrictions and you can't use sprinklers, so hell just pour mega litires onto it with the garden hose instead!). Second gear, 4.5k on the tacho and slip your foot of the clutch.
If he's reallybleepoff with you, then you have an open diff, if he's REALLY - REALLYbleepoff with you have have an LSD. :-)
Note: I don't condone the destruction of other people's property nore do I suggest anyone actually do the above! :-P LOL
91284
Reply By: D-Jack - Tuesday, Jan 04, 2005 at 20:06
Haldo, before you take option no. 2 I'll give you $1000 for your Calais.
D-Jack
91318
Reply By: Ninja - Thursday, Jan 27, 2005 at 15:56
Hi Haldo...
You can,t tell by ID Numbers or stickers on the Diff.
My Rear diff has a LSD sticker on it but it was taken out and replaced with a ARB Air Locker 150000km ago.. Try one of the other tests eg the one with the Calais.. Just joking..
95157
