Valve Clearances 4.2 GU Patrol
Submitted: Sunday, Dec 31, 2006 at 11:59
Old Johno [NSW]
I have a 2004 4.2 L Intercooled Turbo GU patrol & wish to do the valve clearances myself.
The Gregorys manual I have does not give the clearances at all or even the sequences, so I am hoping one of you knowledgeable folk out there can help.
Oh and I have tried the search but with no luck
Reply By: Member - Ed. C. (QLD) - Sunday, Dec 31, 2006 at 15:31
G'day Johno,
Assuming you have the updated
Gregory's manual# 519 (which covers all of the GU diesels from 1998 to Sept. '04), the TD42 valve clearance adjustment procedure is described in detail on page 99..
In short, with engine at operating temperature, and valves numbered 1-12 from the front,
Rotate engine so that No 1 piston is at TDC on the compression stroke. The TDC mark on the crankshaft pulley will be aligned with the mark on the timing cover, both valves of No 1 cylinder should have clearance, the exhaust valve of No 6 cylinder will be closing and the inlet valve of No 6 cylinder will be starting to open..
Adjust the rocker arm adjusting screws until a 0.35mm feeler gauge slides neatly between the rocker arm and the end of the valve stem on valves No 1, 2, 4, 5, 8 and 9
Rotate the engine 360 degrees until the TDC mark on the crankshaft pulley is aligned with the mark on the timing cover, valves No 11 and 12 have clearance, valve No 2 is closing, and valve No 1 is starting to open..
Adjust the rocker arm adjusting screws until a 0.35mm feeler gauge slides neatly between the rocker arm and the end of the valve stem on valves No 3, 6, 7, 10, 11 and 12...
And there ya have it, hope this helps :-))
All the best in 2007 and beyond.....
Regards, Ed. C
| Confucius say.....
....Not necessarily mechanic!!"Member My Profile Send Message |
212581
Follow Up By: Old Johno [NSW] - Monday, Jan 01, 2007 at 12:19
Ed.
Thanks for the reply. I do have the Gregorys #519 but obviously not the updated version as page 99 in my manual is the description & trouble shooting. There is no mention of the info you have supplied.
I have sent an email off to Haynes the publishers to find out what is going on
Thanks again for your help
472929
Reply By: garryn1292 - Sunday, Dec 31, 2006 at 15:32
I have a gu turbo 2000 model & was told by a Diesel mechanic 13'' Thou Hot.Try ringing this Diesel mechanic on 0248771256 or e mail diesel@hinet.net.au Hope this helps Garry.
212582
Follow Up By: Old Johno [NSW] - Monday, Jan 01, 2007 at 12:40
Thanks Gaarryn1293
472930
