Removing a 2003 holden rodeo head unit
Submitted: Wednesday, Jan 28, 2004 at 17:09
landcruiser100
hey guys n girls
i have a 2003 holden rodeo and i wopuld like to change the head unit.
could any givve me some sought of workthrough on how to do this.
(pics would b great extra if possible)
thanks
Reply By: Truckster (Vic) - Wednesday, Jan 28, 2004 at 17:19
Change the head?
1) Why ?
2) What head you replacing it with?
44644
Follow Up By: howesy - Wednesday, Jan 28, 2004 at 17:36
Not quite clear is it. Maybe he means the head unit of his stereo.
306788
Follow Up By: Truckster (Vic) - Wednesday, Jan 28, 2004 at 17:40
slapping myself, thought of that as soon as I hit send...
rip off the dash cowlings around it undo screws...
306791
Reply By: Savvas - Thursday, Jan 29, 2004 at 11:17
I'm assuming you mean the stereo head unit.
The following is how to replace the stereo head unit in the Isuzu Trooper (or Holden Jackaroo). The Rodeo probably won't be too different.
http://www.isuzu-suvs.com/howto/troopheadunit.html
However, the Eurovox head units installed in Australia are pretty good but let down by lousy speakers. Have you thought about upgrading the speakers first?
44719
Reply By: landcruiser100 - Thursday, Jan 29, 2004 at 18:28
i have a hole system ready i just wanted to know how 2 remove da H/U
thanks 4 dat site
44773
Reply By: Member - Bradley- Tuesday, Feb 03, 2004 at 15:27
if it's the new model, from memory there is a screw or two at the base of the trim (sorry, i pulled
mine about 4 months ago) and 4 or 6 spring clips around the trim section. Remove the screws and pull the trim straight out rearwards, then the head unit is a piece of cake, watch the air ducting is in the correct place when re-fitting and the spring clips are fitted to the trim correctly.
A word of advice, don't use the factory ground wire for your head unit , as the new model is experiencing a lot of trouble with loose groundings in the loom under the dash. the central lock / immobiliser grounds back through the ciggy lighter / power outlet loom ( not real smart i would have thought ) as
well as having trouble with the immobiliser relays .
mine is waiting on a replacement loom section and relay from holden as it regularly strands me when the immobiliser goes into lockout mode.
Run a seperate ground wire to a solid piece of body work - not sub dash structure, and you will avoid any hassles, as
well as cut down on possible interference trouble. Sorry mate no piccies for you though....
Cheers Brad.Moo... everyone knows what a Jackaroo looks like :-)
45308
