Disco 'water' sloshing noise
Submitted: Tuesday, Apr 23, 2002 at 00:00
ThreadID: 1011 Views:2426 Replies:5 FollowUps:2
Hi all, I don't want to start another Landrover war but, I have a 95 V8 disco (which I like and replaced a rangie that I had for 7 years with no probs). When I go round corners there is a "sloshing water" noise emitted from the heater area, behind the dash.It does it whether it's set to hot or cold. Can anyone tell me what might be causing this noise? Also, has anyone had any luck getting their alpine window rust, that all discos suffer, fixed by Landrover?
To all those Landie slaggerofferer, If it's got tit's, wheels, fur or a propeller it's gonna cost you money.......no matter who makes it
Reply By: Marcus - Tuesday, Apr 23, 2002 at 00:00
Scott, the sloshing noise you talking about is not from the heater area but it is rather coming from the very empty area between your ears mate.
Seven years of Landrover ownership taking its toll.
AnswerID: 3041
Follow Up By: Scott - Wednesday, Apr 24, 2002 at 00:00
Thanks for the laugh, that was pretty funny.
FollowupID: 1191
Reply By: Ken - Tuesday, Apr 23, 2002 at 00:00
All joke's aside, and I did have a good cakkle over that one, I am afraid I am no landie lover, Check that the drain tube for condensate from the air con is not blocked causing a build up of water in the bottom of the heater-air con unit. It should be visible as an open tube low down on the passenge side of the firewall.All the best with othe replies to your post! Regards Ken.
AnswerID: 3043
Reply By: Rob - Wednesday, Apr 24, 2002 at 00:00
Scott, I previously had a '92 V8 Disco which had a similar water sloshing noise. It sounded like it was coming from under the vehicle when I turned corners, however I eventually traced it to
the passenger door. LR had plastic plugs in the drain holes and the door was filling with water when it rained or when I washed the car. Removed the drain plugs and the problem went. Check it out.
AnswerID: 3045
Reply By: Kevin Phillips - Wednesday, Apr 24, 2002 at 00:00
Had the same problem with my 95 Tdi on occasions and it was water in the doors. The drain plugs can block up if travelling a lot in dusty conditions - forms a mud slurry when it rains witch sets like concrete. You can ease out the mud plug from the drain plug or just remove the drain plug completely. I chose the former and made it part of every post-trip clean of the vehicle
AnswerID: 3063
Thanks everyone for their response. Gives me something to look at on the weekend, and i'll see the quack about the sloshing in my head.
FollowupID: 1215
Reply By: charl makssi - Thursday, Apr 25, 2002 at 00:00
HEE HEE............
AnswerID: 3115
