Ammeters
Submitted: Thursday, Jan 29, 2004 at 19:17
ThreadID: 10116 Views:2217 Replies:3 FollowUps:6
Anyone got any ideas as to where I may purchase an LED type ammeter? Perhaps about the size of 1/3 of a fag packet. I believe they exist in a form that you can affix with adhesive strip to a suitable place on/in/under the dash.
Checked out the archives and Jaycar, both to no avail.
TaFidei defensor
Rosco
Reply By: joc45 - Thursday, Jan 29, 2004 at 19:34
Hi Ross,
Check out Altronics. They have both a bar graph one (cheap) and an LCD one (not so cheap).
http://www.altronics.com.au/cat.asp?cat=11&grp=430&list=0&pg=1&sort=code
Gerry
AnswerID: 44783
Follow Up By: joc45 - Thursday, Jan 29, 2004 at 19:37
I lie!
the LCD is really an LED numeric display. $74.95, kit form.
Bar graph display is $26.95, kit form. There are quite a few other goodies there on the Automotive section to stir the juices up.
Gerry
FollowupID: 306914
Follow Up By: joc45 - Friday, Jan 30, 2004 at 16:31
If you're technical, you can make one - I used a standard LCD DVM from Altronics, and a 7660 ic to make a split +/- supply to run the DVM module (it must be floated). Then used a standard current shunt. The DVM and 7660 prob cost about $35. Can supply tech details if required.
Gerry
FollowupID: 307014
Reply By: Truckster (Vic) - Thursday, Jan 29, 2004 at 21:48
Did you try Jaycars website, or the store... I find their website sucks...
AnswerID: 44803
Follow Up By: Member - Ross - Thursday, Jan 29, 2004 at 21:55
Web site ..... no joy so far.Fidei defensor
Rosco
FollowupID: 306940
Follow Up By: Truckster (Vic) - Thursday, Jan 29, 2004 at 21:58
I'd try the shop, phone call at least, may get you 1% of joy, sounds exactly like the shait they sell
FollowupID: 306941
Reply By: Member - Nobby - Friday, Jan 30, 2004 at 09:24
Ross.. I have a LCD gadget that shows
1. Digital Voltmeter
2. Temp. inside/ out of Esky
3. Time
As well as give warnings about Battery condition, Ice alert, Memory for Max/Min Temp range on Esky/ Battery.They say it has 8 functions.
Great little unit. Cost $50 from Springers Elect in Bris. Put out by Thermo-Tech. Code no. XC0116Jack at sleep
AnswerID: 44835
Follow Up By: shaky - Friday, Jan 30, 2004 at 17:42
Nobby
have you Springers Elect phone number/web address handy?
thanks
FollowupID: 307019
Follow Up By: joc45 - Friday, Jan 30, 2004 at 23:37
Sounds like the same as Jaycar's.
Doesnt perform as an ammeter tho.
Otherwise it's probably all you need. Jaycar flog one for about $39.
Gerry
FollowupID: 307064
