Power Pack and BA Falcon
Submitted: Saturday, Jan 31, 2004 at 01:21
Rottwheeler
Can I run a power pack to run a 50l Waeco from the power source socket in a BA Falcon.
Reply By: Diamond(due to duck season) - Saturday, Jan 31, 2004 at 17:15
gdat rottwheeler.
the lead that comes with your weaco you can plug straight into your lighter socket and run your fridge.
a better way to do it would be to run 6mm wire from your battery through a fuse and to an extra socket and run it that way.
due to duck season coming
ive decided to hide out
love jemima puddle duck
back after the season
44981
Follow Up By: Bonz (Vic) - Saturday, Jan 31, 2004 at 21:03
Whats the current draw Jemima? Would it heat up the socket too much and cause other problems?If you hold your heart and focus,
you will end up holding your dream
307140
Follow Up By: Diamond(due to duck season) - Saturday, Jan 31, 2004 at 21:44
gday bonz.
read my latest post.
cheers.
ps it diamond again lololdue to duck season coming
307146
Reply By: CHRIS - Sunday, Feb 01, 2004 at 12:55
I have 45 ltr WAECO and have tried it on the power socket in the BA XR 8 and it will only work for a short time before the compressor cuts out (engine not going), however it will operate ok while the engine is running.
45038
Reply By: Member - StevenL - Tuesday, Feb 03, 2004 at 00:37
Rotty,
I run a Waeco 'Outback' power pack in the boot of my Honda Civic. I had a Hella plug installed in the boot with 6mm wire direct from the battery and keyed to the ignition (only has juice when ignition is on). This means the power pack is charging when I'm driving and is running the fridge (CF40) all the time. Fridge does not run from vehicle battery at all. Runs beaut. No mucking around with draping leads thru the car.
The point cost $125 for TJM to supply and fit and gives me protection of the main battery. Nothing to switch over when stopping - all automatic when ignition is switched off.
BTW - the guys at TJM almost had a fit when I gave them a Civic to work on. They usually only work on 4WD's!!!!
When I get the new Prado I will be checking out the voltage drop from the standard rear 12v outlet and possibly replacing with 6mm cable. Anyone 120 Prado owners got any comments or feedback here???
StevenL Playdoe GXL TD Manual
It's on order, Delivery in April '04.
This pic will have to do till then. Can't wait!!!
45240
