<span class="highlight">Solar</span> <span class="highlight">panel</span> for battery saver
Submitted: Sunday, May 12, 2013 at 17:06
AlbyNSW
I was looking at a 5watt or 10watt
solar panel from BitDeals to leave connected to the boat battery to maintain it. I know you can get the little units from Repco etc with the ciggy plug on it but thought for he same money may as
well get a real
panel that is a more powerful
My question is would it be ok to connect one of these directly to a 70a/h battery without a regulator to maintain it or am I better to buy the Repco type unit?
Thanks in advance for your replies
Alby
Reply By: Member - bill f (QLD) - Sunday, May 12, 2013 at 18:35
Hi, I have a couple of the 5 watt ones I leave connected to the rideon & battery for the sounder & radio in the boat.Also a 10 watt one for the battery on the electric fence. None have obvious regulators but could be built in. Work best when battery is fully charged & near new.The 5 watt ones came with both a ciggy plug & clips to go direct to the battery. THe 10 watt works the best but was 3 times the price of the others. Need full sun for as much of the day as possible.
Left connected permanently & haven't ruined a battery yet. That said I don't .connect to new or expensive batteries but to ones that have done service elsewhere. Bill
510907
Follow Up By: AlbyNSW - Sunday, May 12, 2013 at 21:51
Thanks for the reply, the price difference between a 5 and a 10 watt
panel is less than $10 now so price is not an issue I was more concerned if it is suitable to do so
789029
Reply By: olcoolone - Sunday, May 12, 2013 at 19:41
You have to work on how much current your boat draws on standby and calculate
panel size to suit..... base
panel size on 4 hrs per day max sunlight.
So is you have a radio that draws 200ma per hour; over a day that would be 4.8 amps over a 24 hour period and if your
solar panels are only going to put back 3 amps a day you battery over time will run flat.
Any
solar panel is better with a regulator.
510911
Follow Up By: AlbyNSW - Sunday, May 12, 2013 at 21:56
Thanks for the reply.Th ere is no load on the battery when in storage, all the electronics are shut own
The price between a 5 and 10 watt is be negligible so price is not the issue, the concern is whether I will damage the battery from an unregulated supply or overcharge it. The battery is an n70 wet cell
789030
Follow Up By: olcoolone - Monday, May 13, 2013 at 08:31
Your 10w
solar panel will put out about 0.8amps in ideal conditions ..... more like 0.4-0.5 in average conditions, 0.8amps will not destroy your battery but like all things it would work a bit better with a reg........ if the
panel was a fair bit larger then yes a reg is needed.
789051
Follow Up By: AlbyNSW - Monday, May 13, 2013 at 10:28
Thanks for your advice, I will run with the 10w
panel then.
789063
Reply By: Honky - Monday, May 13, 2013 at 11:10
I have always wondered how the cigerette plug
solar panels work if you have the engine turned off??
Honky
510951
Reply By: Member - bbuzz (NSW) - Monday, May 13, 2013 at 16:49
Hi Alby,
I have a 2 watt and it is split into two ciggy plugs which are attached to both batteries in the boat.
I have used it for 5 years so far and both batteries are OK and ready to go.
I have not worried about putting the batteries away fully charged, just how they finish at the end of the fishing day.
The
solar panel is on top of a carport that gets full sun all day.
Seems to be the best solution to keeping boat batteries charged.
bill
510985
Follow Up By: AlbyNSW - Monday, May 13, 2013 at 18:13
Thanks bill, that is the sort of thing I am wanting to do except with an Anderson plug wired direct to the battery, come back from fishing and just plug it in.
If you got to use your boat as much as you wanted to you would not need to do this
789090
