Oil Cooler
Submitted: Wednesday, Feb 04, 2004 at 22:33
Tac
I have just purchased a 2002 4.5 lit Petrol Landcruiser GXL auto, & a 16 ft Jayco offroad pop top ( approx 2000kg - loaded ) to do a complete tour of Australia.
Do I need to have a transmission oil cooler fitted.
Tac
Reply By: Diamond(due to duck season) - Wednesday, Feb 04, 2004 at 23:37
gday tac.
i recon for the $100 odd $ theres worth why not it will ojnly help.
due to duck season coming
ive decided to hide out
love jemima puddle duck
back after the season
45508
Reply By: Old Johno - Thursday, Feb 05, 2004 at 17:56
Tac,
I think if you check you already have a transmission oil cooler
Have a good one
45576
Reply By: keith m - Thursday, Feb 05, 2004 at 20:28
Old Johno is correct. There is a large oil cooler in front of the radiator LHS. On
mine, not satisfied, I fitted a temperature sensor in the auto sump and a guage on the dash. Towing a 2.2 tonne 6m full size van, the temp guage shows almost no movement. Just on one occasion on the Moomby range north of
Tamworth, on a 42degree day, the temp climed to 100 degrees going north up the range and then cooled rapidly on the downhill run. Also, if you read the owners' manual, you will note that there is a warning light on dash for high trans oil temp. I think it lights up at about 120degrees. My advice is that another oil cooler is a waste of money.
45596
Reply By: keith m - Friday, Feb 06, 2004 at 21:37
Oops...sorry, my info was not quite correct. The trans fluid temp warning light is activated when the fluid reaches 150 degrees and goes out when the temp drops to 120 degrees. And the owners manual doesn't mention these temps so I must have contacted Toyata to get them.
45746
