brake controllers for 200 series/EOH system?
Submitted: Thursday, Jun 20, 2013 at 01:28
fisho64
looking at mainly the Tekonshas for a EOH boat trailer and to fit to a 200 series.
When the price of the P2 is so close to a P3, why would you buy a P2?
Also are there any controllers that have a flat mounting bracket, as with these when you remove the controller your left with a mount that is just as intrusive as the controller itself?
A remote head type would be ideal but they are all (it seems) such old technology.
Any suggestions?
Reply By: Member - Boobook - Thursday, Jun 20, 2013 at 06:18
fisho, the P3 is the go.
It will fit in the ashtray hole or with some mods the credit card slot on the right. There are many discussions on this in the 200
forum of LCOOL.
Don't get it mounted to under the dash or it will fly at 1000kmph at you if the knee air bags go off. Older GLX's don't have these though apparently.
513431
Follow Up By: fisho64 - Thursday, Jun 20, 2013 at 09:26
Thanks boobook, i have a 60th which has no kneebags. Its a pity they havent been smart enough to make one with a flat bracket though.
I am curious as to why the P2 and P3 are so close in price?
792146
Reply By: Gone Bush (WA) - Thursday, Jun 20, 2013 at 10:36
Fisho,
I put
mine in the ashtray cavity.
I chose the P2 because it comes with this bracket:
P2 Mounting Bracket
The P3 doesn't have a bracket like this. Using this bracket screwed into the ashtray cavity lets you remove the P2 easily.
By the way, it's OK for the P2 to be mounted horizontally.
513442
Reply By: Member - Toyocrusa (NSW) - Thursday, Jun 20, 2013 at 20:17
As Gone Bush as said, the mounting brackets are different. I would also check though, whether the P2 is suitable for EOH. When I fitted my P2 it wasn't but they may have been upgraded since. At that time, only the P3 was suitable. Bob.
513484
Follow Up By: Gone Bush (WA) - Thursday, Jun 20, 2013 at 20:25
I think the P2 has been upgraded Bob, although the OP should double check.
I was under the same impression but its compatibility was pointed out to me on another
forum.
792200
Follow Up By: fisho64 - Thursday, Jun 20, 2013 at 21:08
The blurb says they are "designed for EOH" brake systems, not sure if they always have been though?
792203
Reply By: GeeVee - Friday, Jun 21, 2013 at 10:35
FISHO,
Toyota fitted a CSL Remote Head Brake Controller to my vehicle (VDJ200). Very neat, small power variable nob alongside the power mirror switch. No intrusion into cabin space.
513506
Follow Up By: fisho64 - Friday, Jun 21, 2013 at 11:53
Thanks gv, done a search for that but cant find anything. Any more info or a link? If i could find a proportional remote head id fit it but never heard of these ones?
792233
Follow Up By: GeeVee - Friday, Jun 21, 2013 at 14:35
FISHO,
Apologies, typo - company is GSL Electronics, webpage www.gsl.com.au. They are based in
Sydney.
792245
Follow Up By: fisho64 - Friday, Jun 21, 2013 at 15:23
yeah found them thanks, looks like the same unit as Redarc, time based not proportional inertia type unfortunately
792248
