Dual Battery Installers (Auto Electrician???)
Submitted: Monday, Feb 09, 2004 at 16:01
Member - Tony G (NSW)
Hi All,
Does anybody recommend an auto electrician in Silverwater (NSW Area) that could install a dual battery into a 2000 Jackaroo and approx 6 cigarette outlets through the vehicle.
I am looking at running the following:
Fridge mounted in rear
2 x Spare at rear for light connection
Laptop mounted at front
2 x mounted in middle
seat for kids
I assume the wiring would need to be heavy duty to run all this stuff.
Also could all please advise on the best battery type?
Many Thanks
TonyG
Reply By: Member -Bob & Lex (Sydney) - Monday, Feb 09, 2004 at 16:09
B & J auto electrical Victoria road Rydalmere on the left before railway bridge 96381544 Brian or Glenn. They have been looking after my 4By & trucks for years, do a great job & won't rip you off just tell them I sent youRegards Bob
Where to next
46007
Follow Up By: Leroy - Monday, Feb 09, 2004 at 18:17
otherwise they will!
Leroy
PS I have no idea!!
307965
Reply By: Groove - Monday, Feb 09, 2004 at 18:20
Just a recomendation,
I never had much luck using a cig socket for the fridge, it always tended to vibrate loose and got hot (indicating a poor connection). I tried different types and in the end gave up. Now I use a differnet type of plug that has a postitve lock when inserted. Hella make them I am not sure what their generic name is, but any decent auto electrician will know, they are quit common.
I got
mine from a place called "all about 12 volt" In Auburn. They are an excelent source for heavy duty cable, plugs, solar gear, fuse blocks,
inverters etc etc. They also do installations and tend to understand the needs of campers and 4x4ers a bit better than your average auto electrician.
I use cig plugs for everything else.
46031
Follow Up By: chrisfrd - Monday, Feb 09, 2004 at 19:09
They are called PT-52 connectors in Germany, where they were "invented". The Waeco fridge cable comes with one "built in" but i would recommend cutting that crappy one off and fitting an unfused one.
307972
307973
307974
Follow Up By: Groove - Monday, Feb 09, 2004 at 20:19
Thanks Chrisfrd
I replaced the original Waeco plug as welll,
307983
Reply By: Member - Wayne - Monday, Feb 09, 2004 at 18:47
Tony
Forget the auto electrician, a good one might fit 3-4 units a year. Go to a 4wd
shop. When I was fitting for 4WD Warehouse at
Kings Park I was fitting 3-4 a week.
Fridges should be wired directly to the second battery.At least 6mm cable, you don't want voltage drop (warm beer).
As for the kids in the middle
seat, I have never come across 12v kids, good idea though turn them off and on when required.
PS Can you get a 12v wife
Wayne
46035
Follow Up By: Member - Tony G (NSW) - Monday, Feb 09, 2004 at 19:22
Wayne,
You make me laugh. Great comment abour 12v wife & kids
TonyG
307976
Follow Up By: Member -Bob & Lex (Sydney) - Monday, Feb 09, 2004 at 21:17
Exactly what my mate did with an anderson plug for the fridge.Regards Bob
Where to next
307994
Follow Up By: rolande- Monday, Feb 09, 2004 at 22:16
Can you get a 12 volt wife that has two speeds and is reversible, now THAT would be handy. Oh, sorry, thats my 12 volt drill!
rolande
308010
Follow Up By: Perry - Tuesday, Feb 10, 2004 at 15:29
I use 2 pin polarised low voltage plugs and sockets for everything 12 volt.
Available at all electrical wholesalers.
308073
Reply By: Cumbo - Tuesday, Feb 10, 2004 at 09:53
Tony
Give Birkenhead Solar a ring at Drummoyne. Installed a dual setup in
mine with adapters and did a great job
CumboTD42
EFS
TX4400
Safari
Snorkel
Rola Racks
Milford Barrier
Engel 39l
46124
