The kennel on wheels is nearly finished.Advice please
Submitted: Saturday, Sep 07, 2013 at 21:28
ThreadID: 104224 Views:2748 Replies:2 FollowUps:3
The kennel is a Isuzu rodeo 4x4 motorhome.It is a 1993 model with a 2.8 ltr turbo diesel under the bonnet.It only has 37,000 klm on the clock.Im told the Japanese dont drive them much but use them to live in.
The kennel i brought in Townsville and had it transported down to warm sunny Melbourne.From the transport yard it was taken to Romsey Auto Care.They replaced all belts,hoses,oil and lubricates and checked the whole thing out for anything that could be a future problem.They also fitted Tough Dog foam cell shocks to it.Yes i kept the old hoses,belts and shocks.Plus they done a RWC for it.Then we went up to Seymour to have it registered and placed in my name.I dont think Gunny was happy about that he wanted it in his name.From there down to Carrolls Springs to try and get its bum of the ground and hopefully then raise the whole thing.They replaced the front torsion bars(18mm) with heavy duty ones (27mm).They also added 3 leafs per side at the rear and replaced the u bolts.It is far better than what it was but the ground clearance is still only average.In saying that they were friendly and did a great job considering what they had to work with.
One of the things im debating is whether to take the top storage box off or leave it on.It has reasonable outside storage with out the top box.The top box concerns me how much weight i can put in it without damaging the roof and making it to tall and top heavy.Plus if i took it off i could then replace it with solar panels.Two things, one the solar panels would be great because i wish to mainly free camp.The second is i can keep a spare tyre and tube up there to give me a back up to my spare. Any advise on that??
From Carrolls Springs it went around to One Stop Caravan Shop in Freight Drive Somerton.Neil and the boys had alot of work to do and done a brilliant job with an owner who kept on thinking of extra things he would like done.And they say only women keep changing there mind.You should have seen me.I will run through some of the things Neil and the guys did.I will explain briefly then put up some pics then explain more.They took out the old 3 way fridge (gas,12v and 110v).Yes you read correct 110v,the Japanese dont use 240v.That was a problem because the old fridge was not earthed so he had to run all new cables to the new one they fitted which is a Waeco 110 ltr, bigger than what was in there.Which sounds easy but they ran there cables before the inside walls were put up.Fitted a 240v-12v battery charger,21 inch TV/DVD,300-600 watt inverter connected to a double power point.Two double 240 volt power points,TV antenna and booster,removed the gas heater(stuffed) fitted 3 lead lights,checked out all electrical s and tested the gas stove.Not to mention work out how other things operate or where they were that i did not know.
To explain the last photo.The lower double power point runs of the inverter,the one above runs 240v.The light switch next to the TV turns the fridge on and off on the 12v side so i can determined when it runs or not.You cant see it but just left of the ariel cable there is a button to turn the TV reception booster on or off.
Poor photo but just behind the roof light there is a knob that makes the TV ariel fully adjustable from inside.The inside lay out of the kennel is as follows.If you find something that you think your four legged mate would be unhappy with please tell me.[gi]84371[/gi
Extra inside storage that Neil managed to gain.
The boys did a good job cutting out holes in the timber to create more storage under the couch.The other thing that Neil had to do was work out the range hood which controls alot of things in the kennel and the gas switch.
Now pics of the 2 guys that will live in this before i explain the rest.
[gi]84382[/gi
The things left to do before the kennel is ready to go.Replace the radio/cd player,the old one is stuffed.Have a uhf radio and ariel fitted.Have a bull bar fitted and see what can be done regarding a Telstra ariel fitted for the phone and internet.So not much more left to do.
The things i will be taking along with us as spares or required items are.Spare hoses,belts ,shockers.Tool kit,jumper leads,snatch strap,tow rope,Tyre deflater,12v air compressor,puncture kit,extra fuel(20ltrs),extra water(20ltrs),workshop manuel(that will be a joke),Oil,greece,coolant,brake fluid,crc,aerostart(yes it works on diesels),first aid kit, and a few other bits and pieces.
Is there anything major i have left out??
I know that this van has limitations on what it can and cant do.I will not be doing anything extreme but it should take us to most places i wish to visit.Can anyone offer advise on what else i can do to try and make the kennel more practical or user friendly for out back travel.
To all the hard core of road guys and there rigs looking at my van Gunny and i do not bat for the other team.We will be staying in it for extended periods of time so i have tried to come up with something that is practical and liveable.
Any advice,suggestions or comments will be appreciated whether it be good or bad.
Reply By: MUZBRY- Life member(Vic) - Sunday, Sep 08, 2013 at 08:20
Gday Stuart
I would be checking the age of the tyres, if they are original , then they are twenty years old .
AnswerID: 517797
Follow Up By: Member - Stuart and Gunny - Sunday, Sep 08, 2013 at 10:01
Hi Muzbry
The tyres have been recently replaced they still have little bits of rubber on the side walls.I might see you in November for the long table weekend.
Bye Stuart
FollowupID: 797517
Follow Up By: MUZBRY- Life member(Vic) - Sunday, Sep 08, 2013 at 17:22
That will be good Stuart
FollowupID: 797546
Reply By: Robyn R4 - Monday, Sep 09, 2013 at 20:55
I don't have "advice please" but I do have "looks like a lot of good times ahead!"
Our "kennel on wheels isn't much bigger than a 6x4 trailer and only contains double bed, tv, power points, shelves and space for the dog to sleep (yeh...my dog's much smaller than yours!)
I'm envious of the good times that will lure you.
It looks great!
PS: Is there enough space for dog food to be packed in bulk? Can you store towels for mopping up after wet-doggy-fun-times? Is there somewhere to put the food bowl and water bowl? Is there space for a doggy bed? Has consideration been given to packing doggy toys?
AnswerID: 517886
Follow Up By: Member - Stuart and Gunny - Tuesday, Sep 10, 2013 at 17:51
Hi Robyn.
There is plenty of space for bulk food and his toys.Im lucky with Gunny that he has excellent blader control plus he lets me know when he wants to go to the toilet.As for sleeping arrangements he will sleep on the couch or bed depending on what mood he is in.I take it you and your partner dont have many romantic moments when your camping. Two people and a 4 legged human in a 6x4 trailer that would be a tight fit.Happy camping and enjoy yourself.
Bye Stuart and Gunny
FollowupID: 797693
