you are all geniuses
Submitted: Saturday, Feb 14, 2004 at 13:17
glenno
thankyou to everyone who replied too my post geniuses only apply . happy 4wding.
Reply By: Roachie - Saturday, Feb 14, 2004 at 14:37
Glenno,
One thing nobody mentioned in their replies which you may want to keep in mind..... IMHO it is not ALWAYS necessary to use a bridle when winching. You only need to spread the load across both chassis members when you are so badly stuck that there is a risk of twisting the chassis if you use one recovery point only. You would need to be stuck in mud up to you diffs etc.
I noticed in a large double page ad for TJM in the latest issue of 4WD Monthly that a 75/78 series is featured. The photo clearly shows the undercarriage section under the bullbar and 2 recovery points. Yjey appear to be largish steel plates, presumably bolted to the chassis where the bullbar is mounted and hang down a bit with largish holes for a bow shackle.
Hope this helps.
Roachie
46688
Follow Up By: glenno - Saturday, Feb 14, 2004 at 16:30
thanks roachie i will have a look .
308647
Reply By: Topcat (WA) - Saturday, Feb 14, 2004 at 22:17
Hi Glenno, I may be coming in at the tail end of your query, but this may help you.
I run a 75 series troopy with a X9 super winch. When I fitted the winch, I added a couple of 15mm thick x 75mm wide flat bar straps which are long enough to extend from the bull bar securing point through the front of the bull bar fascia plate
(cut a slot) & have a 20mm hole drilled 30mm back from the end to fit a couple of 3 tonne bow shackles. I used longer high tensile bolts to secure both the plates & bull bar to each of the chassis rails.
When winching using a snatch block I come back onto either one of these points. When snatching I use a length of high tensile chain secured to both points & the snatch strap eye & when tension is applied the "A" angle between the snatch points is 60 degrees to that the strain on the points is applied in a forward direction & not tending to pull inwards. You will need about 3 meters of chain to achieve this angle. I have wiched & snatched using this setup without any problems. Cheers.Have
Wheels Will Travel
46726
Follow Up By: Wayne (NSW) - Saturday, Feb 14, 2004 at 23:45
I know I have said a lot over the past weeks, but I can not belive that anyone would subject any high tensile chain, or any chain, to a shock loading.eg. snatch recovery. Dont worry Topcat you are not the only one. I have had my say and will not comment on this subjuct any more.
Wayne
308683
Follow Up By: Topcat (WA) - Sunday, Feb 15, 2004 at 00:05
Each to his own methods but if you do it properly the chain is not subjected to shock when the strain is taken on. Cheers.Have
Wheels Will Travel
308685
Follow Up By: glenno - Sunday, Feb 15, 2004 at 09:17
wayne i would only attach a snatch strap too a rated hook that was attached to the chassis . but seeing i cannot do this on the front because there is nowhere to put a hook on the front chassis i will not be putting a snatch strap anywhere near the front of my vehicle . this is what i have decided .
308709
