Buying a pathfinder
Submitted: Tuesday, Apr 30, 2002 at 00:00
matt
Hi, i'm looking to buy a 93-95 nissan pathfinder. Its going to be my first 4WD.
What's peoples opinion on the model and age pathfinder?
Any common faults i should look for?
Thanks Matt
Reply By: Cracka - Saturday, May 04, 2002 at 00:00
Gidday there Matt,
I have a 92 Terrano, same thing just a diesel version and couldn't be happier with it. It does have it's ground clearance problems when you're all loaded up but, if you are aware of that when traversing problem areas it's not something to be concerned about.
Problems are few with the Pathfinder, and keep in mind I don't know anything about your motor, look for rust around the wheel arches and uneven wear on the front tyres. That's about it Matt. If you are kooking for an extreme use fourby look at something else. If you want something that will do medium duty with ease, then a Pathfinder will do anything that a medium duty fourby will, Pajero, Musso, Jackaroo, that sort of thing. The only advantage that the Jack and Paj will have over you is ground clearance. And in most situations, smart driving will get you around or through those areas.
Cracka.
3327
Follow Up By: Matt - Monday, May 06, 2002 at 00:00
thanks Cracka, but a day late, fortunately I have purchased a pathfinder 95 year and you have given me no reason to regret me decision
1362
Follow Up By: Cracka - Monday, May 06, 2002 at 00:00
Yeah no worries Matt, that's my life story. A day late and a penny short!
Cracka
1367
