unichip
Submitted: Tuesday, Feb 17, 2004 at 15:17
10 Para
Anyone fitted a unichip and if so what effects have they had we have a 4.8 Patrol Going soon can't wait
Reply By: flappan - Tuesday, Feb 17, 2004 at 15:34
Holly smoke . . . how much power do you want . . . .
I have heard reports of them fitted to both the 4.5 & 4.8 with excellent reports. Would like to do that with my 4.5.
Reports were from the Yahoo Patrol list.
47063
Follow Up By: 10 Para- Tuesday, Feb 17, 2004 at 16:04
Good day flappan it is not so much the power "that would be nice" looking for info on fuel ie if i will save or lose on it, already carrying 220 litres and tow a camper trailer so looking for other ways of going furthur without adding the weight what is your 4.5 like on the fuel.
BrianGoing soon can't wait
309027
Reply By: flappan - Tuesday, Feb 17, 2004 at 16:11
Never have too much power I recon. Better fuel economy would be nice to.
My 4.5 uses roughly 20/100 l City (
Canberra) , 15 - 17 /100 normal highway , and 20 - 22 towing my campertrailer.
Trying to dig up some old info, but cant get their Search function working properly.
I recall it improved fuel , by about 2 or 3 /100 , which when towing would make a fair diff. I would suspect your 4.8 would be better then the 4.5 though for starters.
I'll keep looking.
47069
Follow Up By: 10 Para- Tuesday, Feb 17, 2004 at 17:10
Thanks for that Flappan, which sort of fuel do you use std or pre and would that make a diff i am useing std at the moment and what sort of camper trailer we tow about 1.5 wet and 1.1 dry.
i would take 20-22/100 but
mine is a bit lower than that we are getting at best 23/100 and thats on the highway, so we need to get it down to around 20/100 and with the fuel we have on board 220 and 4 jerry should get a range of somewhere 1000k-1300k which would be nice and would mean that one could stop and have a look around instead of just making it to the pump. Somtimes you can just see the needle drop on the guage when towing uphill.
RegardsGoing soon can't wait
309037
Follow Up By: flappan - Tuesday, Feb 17, 2004 at 17:24
I just use standard stuff. I used Optimax for 5 tanks , and couldn't see any difference. Apparently the Top BP stuff (98 octane or something) is supposed to improve things , but there isn't a BP close by.
My camper is quite light compared to yours . . . 650 loaded (no
water tanks on it yet), so relatively , you probably aren't doing too bad.
I only have standard Tanks (130l) and range is 650k's with trailer.
If you have the cash, then a Unichip would help.
309041
Follow Up By: Savvas - Thursday, Feb 19, 2004 at 08:50
Hi Flappan ... Shell Optimax, BP Ultimate &
Mobil Synergy 8000 are all essentially the same fuel.
I see no or very little difference in economy while running any 98 around town. Certainly not enough to justify the extra cost. But I do see upto a 10% improvement when running on freeway or when towing in our Jackaroo, and I will start filling up with 98 2 or 3 tankfuls ahead of any planned trip.
309280
Reply By: joshinthecity - Tuesday, Feb 17, 2004 at 16:30
Never used one on a Patrol.
But I have with my two previous ( petrol ) vehicles. Very impressive. Totally recomended.
Josh.
47072
Reply By: Rod E B - Tuesday, Feb 17, 2004 at 16:43
Once more for the dummies
What is a " unichip "
Rod
47074
Follow Up By: flappan - Tuesday, Feb 17, 2004 at 16:58
Replaces the factory Microchip in the Vehicles ECU.
Supposed to improve power and fuel economy.
From the reports I have heard . . . works
309033
Follow Up By: Dennis (Brisbane) - Tuesday, Feb 17, 2004 at 17:01
A re-mapped (re-programmed) computer chip that controls your fuel delivery etc.
Runs the onboard computer (ECU) that controls the engine management.
Powerchip is another brand.
309035
Follow Up By: flappan - Tuesday, Feb 17, 2004 at 17:08
Oops . . . pays to reread and check things before speaking . . .my fault sorry.
Unichip is a fully programmable engine management system which allows 408 optimised fuel and ignition parameters to be channelled through a vehicles standard factory ECU to deliver maximum power, optimised drivability and improved fuel economy.
http://www.armadale4wd.com.au/products/unichip.htm
309036
Follow Up By: Member - Bradley- Thursday, Feb 19, 2004 at 11:13
Don't confuse replacement eproms in the computer with 'interceptor' units, The unichip is an 'interceptor' device that allows you to modify the various ecu control signals going to the standard computer, effectively re programming the fuel maps, ignition curves , boost cut , fuel cut etc... Can also be removed and the vehicle sold as stock. Great units, get one fitted by an experienced tuner with a good dyno. Just killin time till
easter...............go and play in the dirt, instead of workin in it......
309291
Reply By: Richard & Leonie - Tuesday, Feb 17, 2004 at 20:41
I asked the
Sydney dealer in Newtown about fitting one to my Frontera. Cannot remember the name but he does a lot of Land Rover work. He was quite upfront about it not working on the Frontera because of the variable valve timing, (I think that's right?). He has a Dyno and tests them before and after. Might be an idea to try and trace him down for an honest answer.
RichardRichard and Leonie, The
grey nomads.
47109
Follow Up By: Member - Edward J - Wednesday, Feb 18, 2004 at 12:25
Probably Graeme Cooper, he does a lot of LR work -
Contact:
99 Princes highway
St. Peters NSW 2044
Phone: +61 2 9550 2689
Fax: +61 2 9519 5984
309158
Reply By: uppy - Wednesday, Feb 18, 2004 at 10:00
can you unichip a 1994 efi gq patrol.10 Para the 4.8 is my dream machine,but three small boys it will remain the dream machine
regards uppy
47174
Follow Up By: flappan - Wednesday, Feb 18, 2004 at 10:20
Its not listed . . . .
309144
Follow Up By: 10 Para- Wednesday, Feb 18, 2004 at 10:27
uppy,
If you have 3 small boys you have plenty of time i would swap the 4.8 for the boys and your age anyday.
Goodluck with them they will bring you as much pleasure as the 4.8 and i am sure you will get the big 4.8 some day.
All the bestGoing soon can't wait
309145
