series 1 disco requires 3inch lift
Submitted: Saturday, Feb 21, 2004 at 17:12
ThreadID: 10689 Views:1743 Replies:2 FollowUps:0
Because of dropping a td5 into my series 1 the front exhaust pipe has to be relocated under the subframe, have considered a 2inch spring and 1inch body lift
to regain ground clearance, what are the problems associated with this.
seashells
Reply By: David O - Sunday, Feb 22, 2004 at 08:15
Talk to ARB. They do a 2 inch spring lift for Discos. Tail shaft angle was a problem when they did my Rangie but they now have that solved.
I am not familiar with the one inch body lift, it may require extension of brake hoses and such but I am not sure.
AnswerID: 47566
Reply By: Slunnie - Sunday, Feb 22, 2004 at 23:29
In that area the bodylift wont give you additional ground clearance, though it may allow you to sit the pipes further up. I'm pretty sure the OME 764 spring, which is a rear 220lb/in 16.9" spring when used in the front will give a 3" lift to the D1. To correct the vibrations the D2 front prop shaft should bolt in, which includes a double cardin uni setup. You may need to run a slightly longer shock (about 2") and lower the brake lines
Mate, well done with the TD5 conversion. I'd love to hear more about it.
AnswerID: 47667
