CRANKING OR DEEP CYCLE??????????????????
Submitted: Thursday, Feb 26, 2004 at 11:50
ThreadID: 10808 Views:2884 Replies:9 FollowUps:12
Hi all,
I thought that i'd better check the search engine before i ask this question, incase i ask it for the 134267 time (didn't want to upset anyone), but as it turns out i didnt realy get the answer i was looking for?
So here it goes: whats the difference between a CRANKING battery and a DEEP CYCLE battery, and which is better for an aux setup? It will be used at a very minimum.
Thanks for any replys.
Reply By: LBJ - Thursday, Feb 26, 2004 at 11:56
Synergist, i would personally choose a cranking. if your not using it too much or only a couple of time a year they are good because the charge alot quicker than a deep cycle. sure they will drain a little quicker too but hey your not gonna be using it that much anyway..............just my opinion
AnswerID: 48193
Follow Up By: Coops (Pilbara) - Friday, Feb 27, 2004 at 00:16
Correct me if I am wrong but I thought a deep cycle was the quicker charging battery of the twoLive the life you love -
Love the life you live !!!
FollowupID: 310176
Follow Up By: LBJ - Friday, Feb 27, 2004 at 10:23
Hi coops, yeah you could be right. a wise old man once told me that a simple way to think about it was" slow draining means slow recharging and fast draining means fast recharging". so i have just followed that.... deep cycle batteries take along time to drain therefor taking longer to recharge than a cranking one, so i have been led to beleive! maybe someone could tell both of us for sure if they read this.........
FollowupID: 310199
Reply By: Jakethe peg - Thursday, Feb 26, 2004 at 12:04
just type in grumpy..i mean Willem
was a thread generated back a few days ago which should help explain
AnswerID: 48194
Follow Up By: Willem - Thursday, Feb 26, 2004 at 19:30
I was tempted to bite but spat the hook out instead....:-)))Willem
Little Dip Cons Park S.A.
FollowupID: 310140
Follow Up By: Member - Eskimo - Friday, Feb 27, 2004 at 10:23
That not like you Willem
not feeling the best eh? heheheWow, am I cute! The extra long legs are built-in prevention against ducks disease. Great looks and a real goer. Doesnt waddle along like some.
FollowupID: 310198
Follow Up By: Willem - Friday, Feb 27, 2004 at 10:30
Richard, you'll go broke if you don't get back to work. Might have to tell your boss you spend all your work time on EO. How about a pic of your truck or haven't you got one?...hahahahahaWillem
FollowupID: 310201
Follow Up By: Member - Eskimo - Friday, Feb 27, 2004 at 10:51
Swmbo wont believe you... cant threaten me that way Willem hahaha
and no i dont have a pic of my truckWow, am I cute! The extra long legs are built-in prevention against ducks disease. Great looks and a real goer. Doesnt waddle along like some.
FollowupID: 310204
Follow Up By: Jakethe peg - Friday, Feb 27, 2004 at 17:04
got over your grumpy mood Willem
good to see...almost got a bite hehehe
Hear your going to little desert ...have fun old man
FollowupID: 310250
Follow Up By: Willem - Friday, Feb 27, 2004 at 19:26
G'day wooden leg :-)
Me.... grumpy?.... never! You guys read too much into these posts and make too many assumptions. But stir the possum I will from time to time.
I am not too sure if cluster camping is fun but we will see what gives when we get to Mexico and the LD campsite. I am taking a detour from here and will probably cover about 800km to LD. Leaving Tuesday arvo and making a trek of it.
Willem
FollowupID: 310261
Follow Up By: Member - Eskimo - Friday, Feb 27, 2004 at 20:34
said it once and I'll say it again...your a tourist Willem...like my wife...never home hahahaWow, am I cute! The extra long legs are built-in prevention against ducks disease. Great looks and a real goer. Doesnt waddle along like some.
FollowupID: 310276
Follow Up By: Willem - Friday, Feb 27, 2004 at 20:56
Why is your wife never home Richard? Maybe she realises the mistake she made marryin' an emu..hahahahaha
Just as well I am a traveller...what would EO be like if I was on here permanently.....may be as be popular as possums on the ceiling....:-)))Willem
FollowupID: 310283
Follow Up By: Member - Eskimo - Saturday, Feb 28, 2004 at 09:39
Willem, No it all started when I gave her a credit card...
No mistake either / She liked the great looks and the fact I'm a real goer hahahaWow, am I cute! The extra long legs are built-in prevention against ducks disease. Great looks and a real goer. Doesnt waddle along like some.
FollowupID: 310333
Reply By: nickoff - Thursday, Feb 26, 2004 at 12:52
Synergist.
The differance between cranking and deep cycle, so I was lead to belives is as follows.
Cranking batteries are designed and built to deliver a large amp delivery I.E. about 80 to 100 amps a short period of time, about 10 or so second, to start the engine and allow the alternator fitted to the vehicle to take up the load of poweri9ng the vehicle and replace the charge taken from the starting battery as quickly as possible, so as to be ready for the next starting cycle. This is why starting batteries are rated in CCA's ( Cold Cranking Amps) and not Amp/Hours.
Deep cycle batteries are designed and built to supply a constant "light current" over a longer period of time and this is measured in Amp/Hours. My 80 Amp/Hour battery is rates 4 amps @ 20 hours. If you take a higher level of current from the Deep Cycle battery it shortens the usage time considerably.
I.E. 8 amps per hour will only eaqual about 8 hours of use, not 10.
However, you should not discharge the battery to this level, At most you should only discharge to 50% of capacity and the recharge, and this will have a life limiting aspect on your deep cycle battery. A battery life is limited by the numer and depth of discharge/charging cycles. The deeper the discharge between charges, the lesser the number of cycles that you can achieve.
Most battery manufactures reccomend a discharge level of about 25% of capacity before recharging, to atain the highest number of cycles available for a deep cycle battery
Another point to remember is battery maintance. Regular cleaning, to prevent parasitic discharge between the terminals, topping up with disatilled or de-ionised water, (NOT TAP) and kept cool and well ventilated to disperse volitile gasses produced during charging.
Also, no not store the battery in a discharged state, as this allows the plates to sulphate and prevent adaquate recharging to full capacity, and thus slowly ruining it.
I would suggest reading a couple of battery manufactures sites re recharge cycles etc, and the site operated by MEGAPULSE, as this give a lot of informanion.
Cheers Nick.
AnswerID: 48202
Reply By: ThePublican - Thursday, Feb 26, 2004 at 16:16
Check post 5920
AnswerID: 48222
Reply By: KiwiAngler - Thursday, Feb 26, 2004 at 16:48
http://www.uuhome.de/william.darden/carfaq.htm
AnswerID: 48224
Reply By: ianmc - Thursday, Feb 26, 2004 at 18:01
Something to look at with a deep cycle as second battery is WILL it start your motor, particularly a diesel, if the main starter battery is dead or discharged?
I feel it is great insurance to have two batteries either of which will start your motor. It is more vital than a few coldies in the frig. I have a much abused Delkor starter battery from which the frig has often been run before putting in an Exide Endurance as no2. It too has been abused & still comes up for more.
AnswerID: 48231
Reply By: Shaker - Thursday, Feb 26, 2004 at 19:05
I believe unles you crank up your charging voltage to about 15 volts, you won't fully charge a deep cycle battery.
AnswerID: 48243
Follow Up By: Wayne (NSW) - Friday, Feb 27, 2004 at 00:12
Problem with that is you are running a 12 volt system. Any more than 13.8 volts and things go pop. A deep cycle battery can take a long time to recharge. Good battery isolaters will slowly recharge a deep cycle battery over a long time, that is how a deep cycle battery is ment to be charged.
Wayne Always Out'N About
FollowupID: 310175
Reply By: Martyn (WA) - Thursday, Feb 26, 2004 at 22:11
Synergist,
Should suit you this, they now have such a beastie as a hybrid battery which is a combination of both the deep cycle and the cranking battery, best of both worlds, I've got one seems to work so far, I've tried it winching and also for a couple of days o the fridge, the winching gave it a bit of a shock I think, still seemed OK, I've got 18 months left on the warranty, that's also good. Keep the shiny side up
AnswerID: 48276
Reply By: -OzyGuy- - Thursday, Mar 04, 2004 at 15:19
Synergist,
I use 2 x 80a/h Delkor Deep Cycle Gel batteries wired in parallel with a Pirahna Electronic isolator & 80wt Solarex solar panel.
I camp at the one spot for many weeks, not days, and have to rely on the batteries to be able to deliver the power, I dont have to start the vehicle to recharge batteries.
It is 'horses for corses' if you are prepared to be continually running your vehicle to recharge your battery (s) then a crank battery will do for a weekend (maybe).
The hassle is when you go away for longer you will only have a few days power available to you.
You say "it will be used for a very minium" then the question is.....
is your minium a day or a week?
my choice would be to err on the side of positive power....
a .. Deep Cycle battery.. they are designed to be used continuously run the fridge etc.
AnswerID: 49135
