Site Search
Section Image
wiring up rear work light
Submitted: Tuesday, Mar 02, 2004 at 16:57
Will
any advice on the best way to wire up a rear roof mounted work light?
thanks!
Will.
Advertisement
ThreadID: 10943 Replies: 7
Views: 1611 FollowUps: 3
AnswerID: 48913   Submitted: Tuesday, Mar 02, 2004 at 18:15
Wayne (NSW) replied:
Will,
The work light I have got is on a spring tension bracket bolted to the roof rack. Didn't weld the bracket because of vibration and could crack.
Most work lights are only 55w so a relay is not a bad idea. Wire the relay from the second battery with a switch on the dash. Most work lights have a switch in the back of the case which someone else could turn on and with out you knowing and next thing you have a flat battery. I by-passed the switch in the case all together and turn the light off and on from the dash,this means that you can turn it on as a reversing light.
Ran the cable from the relay up inside the snorkel and out through the back of the snorkel head. From there along the legs of the roof rack to the light.
Work really well and is very handy
WayneAlways Out'N About
Reply 1 of 7
FollowupID: 310948   Submitted: Thursday, Mar 04, 2004 at 09:35
Bazza posted:
G'Day Wayne,
Which brand of work light do you have? I've been trying to find one that suits my needs for ages ... but still no luck. I've got a 120 Prado and I'm trying to find and fit a narrow rubber backed unit, as I iintend to mount it on the 3rd unused roof rack mounting position. It has to be narrow in width as I do'nt want it to be higher than the roof racks when folded down.
Regards,
Bazza.
FollowUp 1 of 2
FollowupID: 311024   Submitted: Thursday, Mar 04, 2004 at 18:40
Wayne (NSW) posted:
Bazza,
I have got a Hella round work light. Have a look at www.hella.com.au then click on products and then work lights. They might have want you want.
Wayne
Canning Stock Route 2009
Click Image to Enlarge
Good - Better - Best
Never Let It Rest
Till Your Good Is Better
And Your Better Best
VKS Mobile 2292
FollowUp 2 of 2
AnswerID: 48926   Submitted: Tuesday, Mar 02, 2004 at 19:29
Janset replied:
Hi Will.
I agree a relay is a must, and don't forget a fuse. Now to tell you how I wired mine up, and it works well.
I triggered the relay by tapping into the reversing light, that way when I reverse, I got extra light.
Next step: I spliced a one one diode (bought from Dick Smith for a couple of bucks) between the work light and where I spliced into the reversing light harness. I then ran a Hot wire via a switch from inside the vehicle and tapped into my harness between the Diode and the relay (another way to activate the relay).
So what have I now. When I reverse, I get the Work light to give me extra lighting. And when I activate the interior switch to the work light, I get the work light to come on, but the reversing lights do not come on, (as they are blocked by the diode).
I find that over the years, I have got more use out of the extra lighting for reversing then a did as a work light.
Just another suggestion.
Reply 2 of 7
AnswerID: 48933   Submitted: Tuesday, Mar 02, 2004 at 20:02
Roachie replied:
I've got 2 smaller (golf-ball size) lights on the back of my ARB roof rack. I also wired them to reverse light, but no diode necessary. Instead, I simply use a single pole/double throw switch (which also has a green flashing LED beside it to warn me it's on). In one position the lights come on when I go into reverse. When I flick the switch down, the lights come on too. Green flashing LED comes on either way.
Roachie
Reply 3 of 7
AnswerID: 48949   Submitted: Tuesday, Mar 02, 2004 at 21:39
ThePublican replied:
Is illegal to have such a light able to be switched on when not in reverse gear,, just imagine your cruising down the h/way and all of a sudden a 55/100 watter is switched onto you from the vehicle in front,,,, have mine wired straight to reversing light,, helps heaps at reversing and its no big deal to leave vehicle in reverse and ignition on acc when light needed when setting camp ect.,,,,,,,,,check the ADR ,, not only massive fines involved but how would you feel if your vehicle was at fault causing the previous scenario.??
Reply 4 of 7
FollowupID: 310796   Submitted: Tuesday, Mar 02, 2004 at 23:11
Wayne (NSW) posted:
Publican,
Rear mounted work lights are legal, provided that they do not exceed 55watt , have a work light lense and can be moved or rotated.(not fixed like driving lights on the bull bar),
The only thing they could get me for is that I have the switch in the cabin. The light is supposed to be only turned on from the light it self.
The reason I moved the switch is because some clown turned the light on and flatten the battery.
Just about every prim mover I see has one sometimes two of the lights fitted to the cab.
Yes I can remind drivers behind me that they have not dipped there hi beam, but this does not happen often.
Activities Index
Balloon flight over Melbourne including breakfast Balloon flight over Melbourne including break
Melbourne - VIC
Enjoy the serene spectacle of Melbourne waking gently at sunrise, then transforming into a bustling
Seafood Cooking Class Seafood Cooking Class
Melbourne - VIC
From your seafood and fish cooking class learn how to turn the 'catch of the day' into a sumptuous m
Whitsunday Explorer 4 days/3 nights DORM Whitsunday Explorer 4 days/3 nights DORM
The Whitsundays - QLD
Whitsunday Island holiday package including coach and vessel transfers, backpacker accommodation at
Helicopter Flight - Just the Alice - 10 minutes Helicopter Flight - Just the Alice - 10 minut
Alice Springs and Central Australia - NT
Exciting from lift off to touchdown, take to the sky in one of our bubble-cabined Bell 47 helicopter
Book Now - Things To Do
AnswerID: 49003   Submitted: Wednesday, Mar 03, 2004 at 13:21
Member - Mal (Brisbane) replied:
Will,
By law you need to operate the light from the light. To avoid other people turning it on you also have an in line switch inside the vehicle.
You pull up at night, flick the inside switch to "on" go around the back and turn the light on at the light.
Finished with the light, turn off at the light, turn off inside the vehicle.
Have a beer.
Mal T.
Reply 5 of 7
AnswerID: 49125   Submitted: Thursday, Mar 04, 2004 at 13:14
Will replied:
ok fellas thanks for the reponses. from reading above what i want to do is have the light wired into the reversing lights, plus have a switch on the light (but will only come on if car in reverse. can somebody explain how to wire that up in plain english. i am competent at wiring, soldering but need someone to explain the use of the switch, relay etc first.
Thanks!
Will.
Reply 6 of 7
AnswerID: 49367   Submitted: Saturday, Mar 06, 2004 at 12:52
prado95 replied:
Consider that for roadworth requirements the lamp may have to come on when in REVERSE.
Probbaly get away with in most states that dont have an annual inspection, or unless you flash the boys in blue behind you.
Reply 7 of 7
