setting up solar panel to agm battery
Submitted: Tuesday, Sep 30, 2014 at 20:57
Ive read heaps of information on this topic. I have bought a 148ah agm maintenance free deep cycle battery and dual 60w solar panels with an mppt regulator. My query is exacu how do I hook it all together?? Can I just place my solar panel alligator clips on the terminals as
well as alligator clips that run through a fuse to a 3 point 12v plug to run my fridge and lights off?? Appreciative of any input!!
Reply By: Notso - Tuesday, Sep 30, 2014 at 21:09
Yes, just make sure you attach the red alligator clip to the positive terminal.
A more permanent setup up would be prettier but what you are suggesting would work.
539742
Reply By: atifn79 - Wednesday, Oct 01, 2014 at 17:17
just use the method of soldering to get the terminal permanently joined if you find it suitable and before going for it wiring with right terminal is the most essential one.
539770
Reply By: Member - John and Val - Wednesday, Oct 01, 2014 at 18:54
798,
Your battery positive terminal should connect through a fuse (rated at say 20 amps) to the positive side of your mppt controller (= red clip). The fuse should be close to the battery and the mppt controller should be at the battery end of the cable running to the panels, not at the panel end of that cable.
Not sure what you mean by a 3 point plug to connect the fridge, but DO NOT use the sort of 3 point plug you connect to your power points at
home. You need a socket to suit your fridge, or better an Anderson connector. This should be fed via a fuse (again 20 amps is suitable) from the positive battery terminal.
All negative connections should be made directly to the battery negative terminal.
Hope that helps.
John | J and V
- Albert Einstein
539773
Follow Up By: 798 - Thursday, Oct 02, 2014 at 09:27
Cheers all!! That info is exactly what I was after!! Give it a run this weekend and post the outcome, thanks again!!
825433
Reply By: Member - Bruce C (NSW) - Thursday, Oct 02, 2014 at 10:53
Hi 789,
Here is a drawing of a 12 volt solar setup. This is a typical setup and applies to any lead acid battery setup.
As
John said, place the regulator as close to the battery as is feasible to minimize voltage drop.
Use 6mm cable from the panels to the regulator and from the reg to the battery.
12 volt solar electricity setup
| At home and at ease on a track that I know not and
restless and lost on a track that I know. HL.Lifetime Member My Profile Send Message |
539788
