Hi all
Thought I should share this with the
forum in case anyone else is silly enough to do what I did and it might save them some money if they know someone handy with a soldering iron and basic electrical knowledge. Please do not mess with it though if you don't. This
forum does not want to encourage anyone unqualified to play with this kind of high current stuff. And it only applies to this specific situation.
I use my D250S Dual somewhat as a portable charger between my work Van and Caravan. Playing around with it (as I do) I managed to connect the battery in reverse to the output (charge side) of the unit.
Well that did not help it a lot.
From that point on the input lights would come on if the
Solar or Alternator inputs were "alive"" but the green power light would not come on and no charging output. Oh bugger and the $$$ signs started flashing. So naturally I pulled it apart to have a look see.
For those interested, the negative output terminal connects directly to a 30A standard blade fuse internally (plug in) and then has a normally reversed biased Schottky diode (MBR1035 10A 35V) directly across the negative to positive output of the charger on the internal side of the fuse. Theory being I guess the diode will cause the fuse to blow in the event of a reversed battery connection.
In my case the fuse blew but it also caused the diode to go short circuit - maybe that is also by design - but why not just blow the fuse by using a higher current (>30A) diode so you do not have to replace it ?? Anyway, beware that if the fuse has blown the diode needs checking otherwise you will keep blowing the fuse and or create worse results.
Replacing the fuse and the diode (hence the need for a soldering iron) brought the unit back to perfect operation. I just cut the diode off it's legs and re-soldered to the legs rather than have to de-solder it from the board. This could all be done by removing the bottom of the unit (6 screws).
Also for those interested as it was subject of a previous thread, the
solar input cuts in around the 12V mark - this is not specified in the literature for the unit which only mentions the cut in for the Alternator input and the maximum limit of 22V for the inputs.
The
solar input can therefore be powered (as I do) by any sort of suitable DC power source within the limits of operation therefore and not just
solar. So if it is a fixed installation (eg. in a caravan) and you don't have
solar you can rig to fit a power supply to it using the
solar input to keep the batteries in good nick. It could even be as simple as a laptop power supply that has reasonable current output (eg 19V 3.5A is not uncommon which very roughly would equate to about an 80W
solar panel).
