What happened to the EOTopo comment thread?
Submitted: Wednesday, Oct 22, 2014 at 20:10
ThreadID: 109898 Views:2006 Replies:4 FollowUps:9
Was following this thread with interest as I was thinking of upgrading to the latest version but was concerned about the points made by Traveller, I am now unable to find it.
I hope this site has not been reduced to removing content due to negative comments being made.
Chris
Coddiwomple (v.) To travel purposefully towards a vague destination.
Classifieds: Codan Envoy HF Radio X1 for sale
Reply By: OBJ - Wednesday, Oct 22, 2014 at 20:13
Wanna bet????
AnswerID: 540700
Follow Up By: Bob Y. - Qld - Wednesday, Oct 22, 2014 at 20:28
It wasn't the negative feedback so much, as the less than diplomatic manner in which was delivered by the nomadic one. :-)
FollowupID: 826605
Reply By: Idler Chris - Wednesday, Oct 22, 2014 at 20:59
Everybody has a right to their opinion but Traveller did not respect the opinions of others. I am glad it was removed we do not need disrespectful people on this forum.
AnswerID: 540702
Follow Up By: Idler Chris - Wednesday, Oct 22, 2014 at 21:04
Traveller said EOTopo was crap, I totally disagree I think it is great and an asset to the self drive traveller, and posted so. Suggest you look at the product and if I suits your purposes then buy it, if you do not see a benefit to you then do not buy it.
FollowupID: 826610
Follow Up By: Chris (Qld) - Wednesday, Oct 22, 2014 at 21:23
Was the points about POI's covering road intersection etc. valid or not? I would rather had this point explained rather than the post being deleted.
FollowupID: 826614
Follow Up By: ExplorOz - David & Michelle - Wednesday, Oct 22, 2014 at 22:47
Chris,
There was a lot of carry on (personal attacks and flaming) in the thread but as a community feedback developed product set, if the POI detail is a problem then we will simply create a second sheet at 200K without it. Anyway from my point of view and I have only been using Topo maps forever for traveling, cycling and adventure racing, the features are fine, there maybe two spots in the whole of the the Australian sheet that I think it is not 100% right and this will be addressed in a future release.
You should also take note that a 200K map at 200dpi has an effective on screen scale of 1:100,000 yes 100K not 200K. The POI features we have added are around 6500 across the whole country and are shown at around 15x15pixels on the 200K map of 170,000x165,000 pixels. So in effect they are almost nothing, sure some areas in towns have many in close quarters, but in towns topo maps are poor in feature details anyway as most of the feature details is covered by an area definition called Built Up Areas a polygon of generally solid colour thus masking contour and relief rendering anyway. If a few sections of road are covered then maybe we can address the layer order or symbol opacity or maybe you will just love the detail provided.
Some people wonder about the validity of topo maps showing some features however camping areas and other such features are on-ground visible in nature data elements and as such have every right and place to be on a topographic map. There is not much difference from a building point (standard topo element) to a camp area so in terms of pure topographic element the display and rendering of these elements is actually an enhancement to the map.
Anyway we can argue these points all day, we put a lot of thought into the placements and symbol sizes. If the symbol was for a canal, water body, building point, wind pump, wind farm, mine, cave or other there would be no discussion. We have just placed camps, caravan parks and some specific tourism POIs (like CSR wells etc) as important topographic elements (on ground visual features) of the map and used symbols for each.
To see what the maps look like simply look at the sample images in the shop page for the EOTopo 200K product. The EOTopo Online system shows the elements but they are a little different as they cluster and are click-able but the elements shown on the Online are shown on the 200K - zoom all the way in for a view that is close to the 200K product.
Again if feedback states they are not right or wanted we will simply create a 200K sheet without them. There is and should be no issue. If you buy it and dislike the symbols, styles or layout tell us and we will be driven by the feedback as always. With the new download services we have the ability to deliver updates and/or new sheets easily and these are all covered by the Lifetime Upgrade plan.
Hope this helps.
David
Always working not enough travelling!
FollowupID: 826620
Follow Up By: Chris (Qld) - Wednesday, Oct 22, 2014 at 23:22
Thank you for the very detailed follow up David,
I have been using the previous version of EOTopo over the last few months for a Cape trip, the Canning and Simpson Desert. My only real complaint, except for a few minor alignment problems, was the lack of distance markers, but understand it this has now been addressed in the latest release?
Thanks again and look forward to trying the latest update.
Chris
FollowupID: 826623
Follow Up By: Idler Chris - Wednesday, Oct 22, 2014 at 23:23
This says it all. ExplorOz are trying to produce for us the best possible product. Complaining achieves nothing. If you believe that improvements can be made (and there will always be improvements that are possible) then explain them clearly and they will be considered. It is constructive feedback that will improve and keep relevant, EOTopo.
FollowupID: 826624
Follow Up By: ExplorOz - David & Michelle - Thursday, Oct 23, 2014 at 11:58
Chris,
Yes as stated in the documentation and visible on the sample images (one copied below) there are now distance markers on the map, you can also see some POI markers at 100% scale on this image:
[Image cannot be loaded]
David
FollowupID: 826636
Reply By: BarryR1 - Wednesday, Oct 22, 2014 at 21:13
"Traveller" could also be a bit of a serial pest whose been causing some havoc on other websites recently. Have a little search at his past posts and see how he conducts himself. He's a bit suss if you ask me.
AnswerID: 540703
Follow Up By: BunderDog - Wednesday, Oct 22, 2014 at 22:58
Real suss (Troll) looks like he's posted at least under two names.
FollowupID: 826621
Follow Up By: BarryR1 - Thursday, Oct 23, 2014 at 07:19
Yes I'm pretty sure I know who he is. Has a long history of doing that. Caused a lot of grief over on a few of the caravanner and GPS forums. Used to peddle his own mapping product a few years ago. Poor old Dave A, Dave W, Sir John Paul - lots of aliases. A lot of time spent creating false personas and then flaming people.
FollowupID: 826630
Reply By: Pete Jackman (SA) - Tuesday, Oct 28, 2014 at 18:52
I have both the old and new versions, both are good but the new is better. I thought the new symbols were good.
Any mug can be uncomfortable out bush
AnswerID: 540991
