Recovery Points on Nissan Navara
Submitted: Friday, Mar 05, 2004 at 19:31
ThreadID: 11040 Views:2372 Replies:1 FollowUps:0
Hi All,
I have a Nissan Navara ST-R with a factory fitted alloy bullbar.
Where is the best position to hook up for front end recovery.
The vehicle at present has no hooks at the front, only a oval shaped hole at the front of the subframe.
Should I ourchase a hook and bolt onto the front of the subframe?
Thanks in advance
TonyG
Reply By: Wayne (NSW) - Friday, Mar 05, 2004 at 20:10
Tony,
The chassie is the best place to bolt a rated hook. If two can be fitted, one on each side, all the better. Also make sure you use high tensile bolts. Lets hope you don't have to use them but if you do you know they are safe.
Wayne
AnswerID: 49312
