Sunday, Dec 21, 2014 at 00:29
Hi Trevor
Ours is January 2002 built, so an early one of the "fixed" series; series III, with series II being the one with the most failures. As an auto it can legally tow 2.5 tonne, whereas the same motor in manual is rated to tow 3.2 tonne.
Our caravan is 3 tonne when loaded for a big trip - something we could not do with the Patrol.
Are
young considering auto or manual?
Did it cope with towing? Yes, and if it has its way, would look for its favourite speed of 120 kph :O, on suitable terrain. It was slow on windy hills where you could not get a run-up such as in Tasmania, but these roads would slow most caravanners.
Drawbacks? We did not risk stressing the motor by towing that weight through soft sand or other conditions which would make the motor work too hard. The rating on the gear box is I understand because of the lack of braking ability of the gearbox. With electric braking on the caravan, this was never tested. However the gearbox was tested on two occasions, both after taking a wrong turn, with a standing start at the base of very steep climbs. It was very slow and we believe this was due to the gearbox struggling with the load, almost like driving an auto car into a brick wall; the motor doesn't stall, but the car doesn't go forward very far.
Fuel consumption? When towing our Bushtracker, we averaged 5 kilometres per litre. Not towing 7 - 8 kilometres per litre. Our smaller camper prior to the caravan made some, but not a lot, of difference to the fuel consumption. It is more fuel efficient than our present tow vehicle, an F250.
How did we protect it? In view of the hand grenade tag, even with the later series, we fitted and EGT gauge and if it went too high, cut back on the pedal. Also a boost gauge; again if it went high, cut back.
This vehicle has to be the most reliable we have ever had. Now at 180,000 or so, it has had no mechanical failure or work done other than normal servicing.
I would not like to use a 3 litre for heavy towing long term; it it likely to have a reduce motor life.
The old 4.2 motor goes on for ever, but is a 'slug'.
830124
