AnswerID: 3491 Submitted: Monday, May 13, 2002 at 00:00
steve
replied:
I have a CCF-40, which I have been running for several years now (it was one of the first sold). This
fridge has been running basically
every day since the day I bought it, and has been to
Birdsville (in 40+ heat) and all the corrugations around
Betoota,
Simpson desert, Maree,
and numerous other trips. I rate it higher than the Engel. The Danfoss compressor can be fixed almost anywhere. The concerns raised by
other replies regarding the plastic case are, I think, misguided. The metal case of other fridges dents whereas this case bends. It has not
had any marks left on it or suffered any problems. I do agree, however, that the tie down points aren't that great - however,
Waeco has
fixed this and as of last month, all CCF's come with tie down handles as per the new CF50 (I don't think this has been addressed on the CC
range). The
fridge has never run down my second battery, even when the car has been stationary for several days, and everything has
been kept frozen - even when thawed esky blocks were put in to refreeze overnight none of the other contents were thawed during the
process. I use one of the insulation bags (as well as the 240v converter when running the
fridge at home), and to be perfectly honest I'd
buy another
Waeco in preference to anything else. Another advantage of the plastic case is the weight saving over the metal fridges.
Another comment regarding a reply above about the compressor having to run more often - what this is, is theactually the fan running to
circulate air, and this is done rather than use all that extra space for the mesh grille to allow air to circulate naturally. Given that the
fridge
works in the car most of the time, I'd rather have the electronic fan to force air through the condenser area rather than rely (rather
hopefully) that fresh air will manange to work its way around everything packed in the car and thus provide the necessary heat exchange.
Reply 5 of 5
