nissan patrol electrical experts help needed
Submitted: Saturday, Jan 31, 2015 at 15:33
Bega Boy
greetings all , have an electrical issue , started with high beam turning off on main head lights but the spotties and light bar wee staying on , on closer inspection found that after the high beam has been turned off , I still get 6 volts on the high beam circuit ( when on I get 12 volts ). When I
test without the globe in ... It goes completely open circuit .... Would I be correct to presume the globes are " leaking " and allowing 6 volts to continue through even after high beam is off , this is just enough current to maintain power to the relay ... Has anyone else ever had this issue ? Globes are new and cost about $80 and since lost the receipt ...... Don't have any spares to
test ..... So has anyone else had this issue ?
Reply By: Member - Bentaxle - Saturday, Jan 31, 2015 at 15:53
Bega Boy try the Patrol 4x4
Forum website, they will be your best bet.
| May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
Lifetime Member My Profile Send Message |
545116
Follow Up By: Bega Boy - Saturday, Jan 31, 2015 at 16:02
Tried them , comes up saying webpage not found , even after following there page from Google ??
832646
Follow Up By: pop2jocem - Saturday, Jan 31, 2015 at 16:55
link
Dunno, seems to work for me.
832649
Reply By: Member - Bentaxle - Saturday, Jan 31, 2015 at 17:31
Did you have right address: Patrol4x4.com
545123
Reply By: SDG - Saturday, Jan 31, 2015 at 18:46
Had similar problem with two of my Patrols.
The light control switch/stalk thingy had to be replaced both times. Can't remember exact problems, but it was something along the lines of them not being able to handle the current. Both
mine were GQs. Mainly occurs with high wattage spotties apparently. (100w)
I ended up cheating by using the isolating switch to turn them off as needed.
545131
Reply By: Rangiephil - Sunday, Feb 01, 2015 at 15:03
If you add anything to your headlight circuit ( even stronger bulbs) you should add relays into the circuit so that the headlight switch only is subject to a tiny current to switch the relays.
There are lots of relay circuits around which usually include a male plug the same as the headlight plug to activate the relays so they are plug and play.
You will also find your lights will be brighter as there is usually much less voltage drop with the relays.
Regards Philip A
545166
