2002 Toyota hilux d/cab turbo diesel
Submitted: Tuesday, Mar 09, 2004 at 01:02
ThreadID: 11112 Views:26594 Replies:6 FollowUps:1
Hi everyone
Just wondering if anyone has a 3 litre turbo diesel hilux at all , and if so can you please give me some info on what they are like towing wise. Will be towing a 16 - 18ft poptop caravan ( still to purchase) will the diesel handle the van ok ??, havent bought the hilux yet , but pretty well made my mind up that that is what i want. Any info anyone can give will be greatly appreciated
Thanks and cheers to all .........Dave
Reply By: farmer - Tuesday, Mar 09, 2004 at 10:46
When I had my TD D cab Hilux I pulled a Trakshak which when loaded weighed over one tonne. It pulled this effortlessly. You didn't even know you had it on the back. Now I pull it with a TD prado and it does't pull it quite as well. You have to use the gears more and drive a bit harder.The Hilux is a very good vehicle, reliable, tough ( why can't you spell it " tuff " ) and a lot of room in the back to carry things. When you put a trailer on the back it doesn't sag like the Prado.
The tyres that were on it when I bought it were hopeless up north. The gibber country played havoc on them. I putt BFG on and then never had a flat again.
I found out the the speedo was about 6km out ( using a GPS ) but when I put the bigger BFG's on the speedeo was nearly exact. I think from memory the BFG's were 30 - 10 - 16 or was it 31-10-16 I will have to check up on that.
AnswerID: 49637
Reply By: donk - Tuesday, Mar 09, 2004 at 11:02
I can not help you with a Turbo Diesel Hilux but i have a 98 3 litre n/a Diesel Hilux that i tow a 16 foot Jayco pop top with
The Hilux's have a towing capacity of 1800kg with 180kg on the ball & i think you will find that a single axle van of around 16 foot external will be all that you can legally tow
Our jayco is plated at 1260kg tare + around 300kg in personal gear & supplies so weighs around 1600 to 1700 kg loaded
If you go any longer than 16 foot it will normally be a tandem & the additional weight of axle,suspension & wheels will normally go over the 1800kg allowed
As far as towing the turbo should not be underpowered (mine is) as the engine is the same (but without the intercooler) as fitted to the prado & they are ably to tow vans of around 2200 to 2400 kg without to much drama
One problem is the hilux is fairly narrow compared to most vans & you need to fit fairly wide towing mirrors to see past the van
The stability of the hilux is good with the van in tow (i use a 2500 kg Hayman Reese Weight Distributing Hitch)
The only thing you need to be aware of is that most vans have a low drawbar height (on road vans made for towing by sedans,ect) & the hilux towbar is fairly high so you may need to get a drop down tongue to make the heights the same
Hilux's are reliable & not a bad all round vehicle & don't have any major problems
The Navara Diesel can legally tow 3000 kg so if you are looking at a van larger than 16 foot long this may be something to look at although my choice would be the hilux if towing capacity was not a issue
I hope this information helps you
Regards Don
AnswerID: 49638
Reply By: bluehealer - Tuesday, Mar 09, 2004 at 21:04
have a 2003 td hilux towing a 1250 kg van unladen ,needs a bit more grunt to sit on 100 kliks ,standard tyres ,fuel econ omy about 16 to 19 ks per hundred ,not really impressed or am i pushing too hard, have only towed about 800 ks so far,thinking about putting a chip in,trying too sort out any problems before i go north late next month,otherwise happy with the lux at the moment
AnswerID: 49701
Reply By: bluehealer - Tuesday, Mar 09, 2004 at 21:16
should have been litres per 100 kliks, and its a twin cab.
AnswerID: 49703
Reply By: Member Eric - Tuesday, Mar 09, 2004 at 22:26
Have a Diesel 99 hilux dual cab 165,000 . motor just blew up , cost to replaice around 4 k .
AnswerID: 49712
Reply By: itisi - Tuesday, Mar 09, 2004 at 23:06
G'day all
I have had a '94 Hilux Surf with 3.0 ltr turbo diesel for 4 years+ and have been towing our vans for the same length of time. Our current Viscount Overlander van (15ft) is the lightest @ 1200Kgs GTM. Previous vans (1st one) were Jayco 14.5ft @ 1300kgs and then a Coromal 17ft @1450kgs (single axle, bout the largest you can go before tandems).
Used to live in/around Newman W.A but now down south of Perth. Having travelled quite a bit around the north-west W.A and still "GO NORTH" once or twice a year, can fully vouch for the 3.0 ltr turbo motor. Sure there are times when you have to slow down up steep hills but you then have the down side where you pick-up speed again! Have seen lots of bigger vans being towed out there by a lot lower powered vehicles and they still get around OK.
Go for it
Happy vanning
Rod (Itisi)
AnswerID: 49719
Follow Up By: borgy adelaide - Thursday, Mar 11, 2004 at 00:59
Thanks everyone for the very informative responses, i think i will go with the hilux , have been a nissan man for the last 10 years but after all the probs i here about the 3 litre patrols i have decided a change is as good as a holiday, i would realy like to have a 4.2 litre GU , but unfortunately a little out of my price range. .................Cheers everyone...........Dave
FollowupID: 311688
