Sump gasket
Submitted: Tuesday, Mar 09, 2004 at 09:01
ThreadID: 11114 Views:2412 Replies:6 FollowUps:1
Hi guys
98 Series 1 Tdi disco with weeping sump gasket (mainly at front). I understand that Landrover don't use a 'gasket' but some form of sealant instead. Anyone had this problem before, and any ideas as to the size of the job to fix?
Steve
Reply By: thomo - Tuesday, Mar 09, 2004 at 09:42
Its a landy of course they have had this problem before.
AnswerID: 49632
Reply By: Mick - Tuesday, Mar 09, 2004 at 12:10
This is a standard anti-rust system, which pommie engineers have worked on since the landrover was created!
AnswerID: 49643
Reply By: Barry F - Tuesday, Mar 09, 2004 at 13:04
It's an English thing!! when it stops leaking thats when you worry!!!!!!!!! see if you can get on to classic car club that specialises in old pommie cars or even bikes they have sealents that are designed for this job, i think from memory there is one called hermilite, not positive though, old you know, lotsa beer hence lost a few brain cells, hpe this helps good luck. Bazzar.
AnswerID: 49652
Reply By: Aston - Tuesday, Mar 09, 2004 at 17:57
steve,
Its a shame that the others couldn't have been more helpful instead trying to be funny.
But bazzar was trying to help ..the product that he was trying to remember is "hylomar" this is not suitable in this situation.
Use Loctite 587 "Blue Maxx" or Wurth 250, Threebond 1207C.
crack the sump off and use any of the products above and that should fix it.
Cheers Aston
AnswerID: 49682
Follow Up By: Member - Barry F (NSW) - Wednesday, Mar 10, 2004 at 20:30
Hylomar thats it, sorry been a long time since i've worked on pommie stuff being an ex motorcycle mechanc and racer it takes it's toll, you know, old habits die hard.
FollowupID: 311635
Reply By: Mark - Tuesday, Mar 09, 2004 at 21:20
Steve,
From the forum at http://www.lrenthusiastforum.com
The overhaul manual for the TDi shows that the bolts are removed in a similar sequence to cylinder head bolts, starting in the middle at each end and working round. Apply a 2mm bead of Hylomar Instant gasket 302 (black) - sounds like a silicon sealant to me - ensuring it is inboard of the bolt holes. Fit sump within 30 minutes and tighten bolts in reverse sequence of disassembly to 25Nm.
Also check http://www.sf.hiof.no/~frodehaa/disco.html you can download the 300TDI manual under Servicing a Disco - Engine
AnswerID: 49704
Reply By: Discovery - Wednesday, Mar 10, 2004 at 09:22
Guys
Thanks for the info - much appreciated.
Steve
AnswerID: 49747
