Shower cubicle
Submitted: Monday, Mar 02, 2015 at 20:55
Member - Jorgen S (QLD)
just bought van with full ensuite. My plan is to polish the one piece plastic shower cubicle
with
Turtle Wax. Is that advisable? or should i use something else to make it easier to keep clean? Any thoughts
Reply By: Idler Chris - Vic - Monday, Mar 02, 2015 at 21:15
If you did that would you not end up going a over t?
546853
Reply By: Michael ( Moss Vale NSW) - Monday, Mar 02, 2015 at 21:32
If its acrylic, you can use Brasso for a very glossy finish but you better spot
test in an inconspicuous area. You can use Brasso on gelcoat if its fibreglass also.
Turtle wax has no cutting power if thats needed but you could use it after for a clean beading affect. But of course, be careful. Michael
| Patrol 4.2TDi 2003
Retired 2016 and now Out and About!
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
546855
Reply By: TomH - Monday, Mar 02, 2015 at 22:15
Dont do the floor You do want to remain vertical We just used shower sparkle
546858
Reply By: Member - John L2 - Monday, Mar 02, 2015 at 22:21
Hi Erik Just use non soap shower jell and a squeegee after you finish showering.
546859
Follow Up By: Fab72 - Tuesday, Mar 03, 2015 at 16:56
I second the pump bottle shower gel and a quick wipe with a chamois.
Prevents soap scum build up in the first instance. That's what we use at
home and I swear by it. (It's my job to do the shower cleaning).
Fab.
834735
Reply By: Rob J8 - Monday, Mar 02, 2015 at 22:48
My wife said she uses a plain wrap Mr Sheen and we wipe it out after every use.
we have owned the van from new and after nearly 3 years it is as good as new.
We are heading
home to the West next week after living in the van for 8 months.
Hope this helps.
Rob J
546862
Reply By: Les - PK Ranger - Tuesday, Mar 03, 2015 at 08:35
If the paint of fibreglass gel coat is in good condition, I agree wiping down the shower after use is good to keep perfect, have one of the softer spray cleaners in there.
A quick spray and wipe with soft cloth and rinse by the last person having a shower that day.
Don't use those microfibre cloths or blocks, they will dull it and make it hard to clean (ok on glass, not acrylic or fibreglass.
If the paint is in poor cond, then consider getting it professionally 2 pack spray painted.
It will last a decade + if looked after the same as above.
546869
Follow Up By: Les - PK Ranger - Tuesday, Mar 03, 2015 at 10:58
. . . paint OR fibreglass gelcoat.
Oh for an edit button (or careful pre post perusal :/)
834703
Reply By: Brad R2 - Thursday, Mar 05, 2015 at 18:35
I have
turtle waxed the walls of our last 2 vans shower cubicle and it lasts about 6 months. The water beads and runs straight down, made better if you use the shower gel as suggested, even better if you use the squeegee as
well. It's certainly preferable to not doing anything and makes cleaning a lot easier.
549469
