Help! Need Wheel alignment shop at SE melbourne
Submitted: Thursday, Mar 11, 2004 at 21:23
2ndLow
Guys, any good wheel alignment
shop you would recommend ? After a 2.5 inch lift on my LWB GQ, the steering is terrible. I have to constantly turn the steer wheel about 3-5 cm to right to keep the car going straight . It was about 2-3cm b4
suspension lift. It is definitely not caused by camber of road.
Please help........any recommandation ? I don't think normal tyre
shop can do proper job.
Reply By: Member Eric - Thursday, Mar 11, 2004 at 21:26
Total Tyres in Oakleigh do a good job
50000
Reply By: Truckster (Vic) - Thursday, Mar 11, 2004 at 22:29
I would take it back to where you got it installed. Their problem.
I think you need to look closer at other things that may be bent, or worn. Or a caster kit for it, but thats almost unheard of on a small lift like that.
You mention it was an issue before the lift, so the lift has exaggerated the issue. Meaning something could be bent.
Ive done 5 or 6 x 3inch lifts on GQ LWB's and none have ever had an issue like you describe.
Again, I would take it back to where you got it installed. If you need someone to check it out, go see Alan at Outback accessories in Seaford.. Hes a GQ man.
50013
