air compressors maxi air
Submitted: Monday, Mar 15, 2004 at 10:23
Member - Steve G (WA)
I was going to buy a compressor on ebay this week , but on the weekend went to a
camping shop and found the bushranger maxi air comp ( not labeled bushranger obviously ) but out of the same factory , and the price
well what can i say what a bargain only $200.00 and one year warranty . that will do me just fine
If any one esle is interested they are at GO
CAMPING erindale rd balcatta
Perth
Reply By: rolande- Monday, Mar 15, 2004 at 10:37
Steve,
Did it have a brand on it? If so which one. Sometimes I struggle to keep up with all the branding so don't know what I am looking at. Are there any serial numbers, marks etc, which identify the compressor.
Rolande
50369
Follow Up By: Member - Steve G (WA) - Monday, Mar 15, 2004 at 10:50
sorry Rolande didn't send it to your follow up
312165
Follow Up By: cokeaddict - Monday, Mar 15, 2004 at 15:36
I had the AIR MAX compressor, it was the best one ive seen used. But be careful of an immitation on the market, its not the real thing,i was told this by a reputable
shop. Looks exactly the same but internals are different.
I sold
mine only because air locker was fitted and came with arb compressor mounted under drivers
seat, but i wish i had kept the original air max now as its chalk and cheese between the too.
Just what ive been told ..correct me if im wrong
312192
Reply By: Member - Steve G (WA) - Monday, Mar 15, 2004 at 10:48
Didn't see any brand on them , but it is the only electric air compressor he does by the looks of it , give him a call very helpful wiyh fridges also .
50370
Follow Up By: rolande- Monday, Mar 15, 2004 at 13:38
Steve,
Sorry, forgot to mention I was in Vic' was hoping from the info to find the same pump over here then haggle down the price from RAY's Tent City, etc.
Rolande
312177
Reply By: Member - Jeff M (WA) - Monday, Mar 15, 2004 at 15:09
I just bought a Compressor from Supercheap, their advertised $79 jobby, stripped all the crap off it and mounted it under the bonnet, works very very
well for $79! I have not timed it so far but seems very good.
50399
Follow Up By: Brian - Monday, Mar 15, 2004 at 16:25
What stuff did you strip of ??
Brian
312197
Follow Up By: Member - Jeff M (WA) - Monday, Mar 15, 2004 at 16:53
The 12vDC Switch (I was using one in the dash) the plastic end housing that contained the switch, those metal frame thingos that were to clip your battery terminals too and the rubber feet. (I cut the feet, drilled through them and turned them into little rubber mounts that my bolts went through. Then I cut the small bit of hose that came out to the quick release end and extended it using high pressure fuel line and hose clamps to the front grill, drilled a small hole in the plastic in the grill and screwed it in there. That way I don't have to pop the bonnet to use it, my hose (that is kept under the passenger
seat) complete with guage just clips in under the front grill and away you go. Of course it's all fused and sealed. Also sprayed fisholine around my new holes as to stop any nasty rust coming through.
312201
Reply By: Member Eric - Monday, Mar 15, 2004 at 17:12
Guys dont be fooled . It is nothing like the real Max air . Defenently NOT made in the same factory , Has on the phone to Bushranger all morning .
I will have great prices for the Real Max air Tomorrow , look out for the post
50410
Follow Up By: Member - Steve G (WA) - Monday, Mar 15, 2004 at 17:55
Eric i have put it next to one of my mates bushranger maxair comp and it looks identical , so dont know what the go is and seems to work just as good .
312212
Follow Up By: Member Eric - Monday, Mar 15, 2004 at 20:05
If you want to test it properly . Put them on 2 identical tyres and take them a high pressure , and listen to both motors when it gets up high
312234
Reply By: Boobook - Monday, Mar 15, 2004 at 20:33
Make your own mind up.
Look at the compressors made by Yuyao Jindun Instrument & Meter Co Ltd of China.
The specifications and picture of the Maxair look remarkably like the JD 101( copy and paste web URL below, - copy all of the long URLfor Yuyao's site)
Yuyao web page
http://www.asia.globalsources.com/gsol/GeneralManager?&catalog_id=2000000003844&design=clean&language=en&action=GetSupplier&page=supplier/ProductDetail&supplier_id=6008803660631&product_id=8836923428&action=GetProduct
Maxair web page
http://www.bushranger.com.au/maxair.html
And the Proair looks and specs are remarkably like the JD 95
Yuayo web page
http://www.asia.globalsources.com/gsol/GeneralManager?&catalog_id=2000000003844&design=clean&language=en&action=GetSupplier&page=supplier/ProductDetail&supplier_id=6008803660631&product_id=8836928948&action=GetProduct
Proair web page
http://www.bushranger.com.au/proair.html
Co-incidence maybe!!!!!!
The JD 101 sells for about $42 if you want to buy a container load ( min order), however three is an exclusive distributor for Australia ( go figure!)
50443
Follow Up By: Boobook - Monday, Mar 15, 2004 at 20:51
Given the links are so long try these ( I hope this works)
Maxair comparison
Yuyao 101 compressor
Maxair
Proair comparison
Yuyao 95 compressor
proair
312240
Follow Up By: Boobook - Monday, Mar 15, 2004 at 20:53
Just tested these links and they work.
For side by side comparison right click on the link and select open in new window
312241
