TJ Wrangler - Leaking Master Cylinder?
Submitted: Monday, Mar 15, 2004 at 14:13
Jay
Hey all,
Just a quick question folks, I was wondering if anyone had had any problems with a leaking Master Cyclinder on TJ Wrangler. Accompanied with that I noticed a slight vibration and a minor grinding feeling feeding back through the brakes when there applied though this is only happens when the Wrangler is nearly at complete stop. I have checked the calipers and they seem fine, so I'm a little stumped at why this is happening? Any ideas would be greatly appreciated.
Thanks,
Jay
Reply By: fozzy - Monday, Mar 15, 2004 at 14:40
know nothing about jeeps but could pssibly be compound of pads
drive a hilux ute round town a bit and if brakes get hot(ie quite a bit of heavy braking around side streets then pads grind-sensation like having metal on metal when no pads left. common problem in hiaces and hilux utes.
first time happened was a little bit nervous re stopping-but brakes still work ok
also could be a wear indicator on pads to alert driver they will need replacing shortly-quick call to dealer will tell u if problem with specific vehicle.
could be something wrong with abs??
50397
Follow Up By: Jay - Tuesday, Mar 16, 2004 at 09:54
Thanks for follow up fozzy, appreciate it. I'll prolly strip her down on the weekend and have a good squizz, if all else fails i'll get a pro to take a look and get a couple of quotes.
312300
Reply By: Baz (NSW) - Monday, Mar 15, 2004 at 20:30
Jay a leaking master cylinder is usualy an
sign of dirt in the seals or just a worn seals a master cylinder kit fixes the problem. assuming there is no crack's in the master cylinder itself or in the lines. Oh Jay most master cylinders are made by a few companies not necessarily made by the vehicle manufacturer. You will find that the master cylinder is made by the same company that Ford or Chev.
Baz.
50442
Follow Up By: Baz (NSW) - Monday, Mar 15, 2004 at 22:45
USE, thats should have been the last word in the sentence.
312260
Follow Up By: Jay - Tuesday, Mar 16, 2004 at 09:56
Thanks for that Baz, I never really thought about that, so i'll check that aswell. The refiller @ the top seems to be leaking out of the bottom O-ring which is only rubber, but it also seems to coming out from under the lid but i dont see how as thats screwed on hand tight? I'm a little stumped on that aswell.
312301
