rear mud flaps on pajero
Submitted: Tuesday, Mar 16, 2004 at 20:23
Rusty bear
Hi went 4wd at
lancelin (in wa if ppl didn't know where that is) all was good paj doing pretty
well then it happened down the steep enbankment which went
well it was getting back up again that caused me grief.
The rear mud flaps acted like big sand anchors as i reached the crest and crack!!!! ripped the rear bumper from tail light to the tow ball.
Has anyone else had this problem or any ideas on how to rectify so as not to happen again.
Would show photo but haven't worked out how yet
Thanking you in advanced
Russell
Reply By: Lynn2 - Tuesday, Mar 16, 2004 at 20:31
Seems to be a common problem with NM/NP Pajeros. Check out www.pajeroclub.com.au for more info
50581
Follow Up By: Rusty bear - Tuesday, Mar 16, 2004 at 20:54
Thanks for that Lynn2 i'll give them a try
312379
Reply By: Savvas - Wednesday, Mar 17, 2004 at 17:42
Check out post 4198 .... seems to be common
50710
Reply By: keepsmilin - Wednesday, Mar 17, 2004 at 21:13
Hi Rus
Just got back from fraser, had simular problem, popped them them both both of, and ripped off the plastic skiddy underneath, the metal one hung on, did it towing a camper trailer on the way up to
lake allom, a good learning curve, wont take the kids and all of there garbage that never got used.....next time.
Plastic under 4 x 4s just doesnt cut it......
good luck Neil
50759
Follow Up By: Rusty bear - Wednesday, Mar 17, 2004 at 21:22
Yeah thanks guys for all your help i think there will be a lift in order and custom metal rear bumpers hopefully that should cure it.
thankyou once again
Russell
312528
