Can Any one help please
Submitted: Wednesday, Mar 17, 2004 at 00:37
ThreadID: 11315 Views:1841 Replies:5 FollowUps:2
My son recently bought a 1998 Ti 4.2 GU patrol after owning it for 2 months it developed an intermittent problem. Runs perfect for days then suddenly will run rough and loose power to a point where it won't drive but just splutter which he finds quite embarassing at the traffic lights not to mention the fact he is very peeved off. He has taken it to a Nissan dealer heaps of times and they can't find out whats wrong with it, thier computer reads everything is fine they have tried replacing the distributor, fuel pump, fuel filter,new plugs,cleaned the injectors and removed an alarm that was fitted before he bought it.
any thoughts on the problem would be greatly appreciated thanks
Snatchem
Reply By: Member - Peter (York) - Wednesday, Mar 17, 2004 at 00:58
try taking the fuel line off at the tank and pocking a wire down it ,years ago I had a similar problem it turned out to be a small bit of rubbish stuck in the internal pick up pipe , now and then it woulld act as a butterfly valve and stop the flow ,it all depended on how much fuel was in the tank ,it took ages to find after almost replacing the whole fuel line .
AnswerID: 50636
Follow Up By: Snatchem - Wednesday, Mar 17, 2004 at 09:19
Thanks Peter, will give that a go.
Snatchem
FollowupID: 312428
Reply By: GUPatrol - Wednesday, Mar 17, 2004 at 09:58
Have you got all your facts right?
1998 TI could only be a petrol 4.5....
TI spec was never available in diesel, then again 4.2 TI petrol was available until 1997 and it was GQ....
AnswerID: 50656
Reply By: Pelesino - Wednesday, Mar 17, 2004 at 10:10
Snatchem,
Check if it has a filter near near the fuel tank I had the same problem with an MQ I used to have.
AnswerID: 50659
Reply By: Member - Bradley- Wednesday, Mar 17, 2004 at 10:32
yeah check the fuel filter/ lines and tank. speaking of stories, when i was at holden we had the local boys in blue bring a new ss chaser in for work, had a bad miss when going hard under full load. very embarrasing for the hot shots to be passed by the cruisers when in a chase lol. So i'm in the seat driving with the boys alongside and we go for a run, sure enough top of third into fourth bam breaking down , back off, power again , same thing. couldnt top 140. They usually do 220 or so (so i've heard hehe). Anyway all diagnostics came back normal, so i drop the tank and remove the fuel sender/ pump assembly - all normal. Then by accident i shine the torch over the tank opening and something catches my eye. One Dirty big rag.. under constant hard accell the fuel pump has no return to the swirl pot and pulls full amounts from the tank, sucking the rag into the pickup and blocking the flow.. No explanation how it got there- it just was...
AnswerID: 50663
Follow Up By: cokeaddict - Wednesday, Mar 17, 2004 at 10:36
Hmmm wondered where that rag got to.
FollowupID: 312434
Reply By: Snatchem - Wednesday, Mar 17, 2004 at 19:20
Ok sorry it is a 4.5, and Magic Nissan could have found the problem today as they found a strange wiring harness attached to the harness going to the computer. Some one (previous owner) has disconected something maybe sat nav and looped wires back into the plug and taped it all up. Here's hoping...
thanks everyone for your help
Snatchem
AnswerID: 50730
