self draining patrol sub-tank
Submitted: Friday, Mar 19, 2004 at 22:48
locallaw
Gidday All,When I fill both tanks on my 1998 2.8 patrol all is
well.As the fuel level in the main
tank drops to approx 2/3 full the sub
tank decides to transfer to the main with no help from me.There is no way I can prevent this from happening.
Has anyone out there had this problem and how did they fix it.
Thanks Locallaw
Reply By: Nomad - Friday, Mar 19, 2004 at 22:56
Sorry locallaw don't think I can help. My 2000 Patrol will run out of full but won't drain the sub unless I hit the sub
tank button on the dash. It will then empty the sub into the main. If you turn off the ignition before it's finished then you have to hit the button again when you start the engine again.
Nomad
51111
Reply By: Willem - Friday, Mar 19, 2004 at 23:59
Might be something to do with the venting of the tanks.
Why does it bother you?
51116
Reply By: Member - Bigbear - Saturday, Mar 20, 2004 at 00:02
Locallaw
This problem is standard practice on my GQ when I fitted ARB main
tank and aux.
Fill them both and it draws down the aux then the main, no switches pumps or anything else mechanical. I know the GU is supposed to work with a transfer pump and the only thing I can think of would be that the breather hose to let air into your main
tank must be partially blocked, therefore creating a restriction and making it draw from the aux
tank. That is my thoughts.
Bigbear
51117
Reply By: Waynepd (NSW) - Saturday, Mar 20, 2004 at 00:09
Hi Locallaw,
As far as I know, the sub
tank pump runs for a pre-determined time at startup on my 98 GU 4.2, is this what you are talking about?
51118
Reply By: fourstall2000 - Saturday, Mar 20, 2004 at 08:55
With the GU 3.0 litre, the sub
tank transfer pump operates for several seconds every time you restart the engine.
This is a design feature to ensure the pump does not gum up from non use.
The result of this is that over several days of intermitittant driving the sub
tank becomes empty.
It is annoying but at least the fuel is always fresh and free from bugs.
Perhaps you system is the same,ask your Nissan dealer or ring tech line.
51128
Reply By: rolande- Saturday, Mar 20, 2004 at 10:43
It does this so you don't run out fo fuel while the sub is still full, as above, runs for a pre-determined time each time the engine starts. Don't understand why this would be a fault? There to ensure fuel mixes and does not go "stale" by sitting in the sub for extended periods. You will find on long trips does not happen due to the reasons already listed. I think its a good system, use it to you're advantage
rolande
51145
Reply By: Eric Experience. - Saturday, Mar 20, 2004 at 22:24
Locallaw.
The transfer pump on all Nissans have valves in them like a normal mechanical petrol pump, these valves alow fuel to flow from the auxilary
tank to the main
tank. The pump does not have to be switched on for this to happen because the motion of the vehicle is enough to force the valves open whenever you go around a corner. Some one started this myth about the pump being turned on by the computer on start up and the myth has become common belief. You will find almost pumps on auxilary tanks do the same even on models without a computor. Eric.
51214
Reply By: Member - Nino F (VIC) - Sunday, Mar 21, 2004 at 11:15
Locallow,
R.T.F.M. read page 1-23 of the owners handbook.This is normal. It stops fuel going stale by ensureing its mixed and used.
51245
Reply By: locallaw - Sunday, Mar 21, 2004 at 18:48
Thanks to everyone who replied.I received quiet a lot of different answers but I have a good idea what is happening now.
Thanks everyone
Martin(locallaw)
51277
