bad odour
Submitted: Sunday, Mar 21, 2004 at 22:38
Lachy
I have had a bad oudour in my LC100. I discovered the smell was caused by wet underlay on the passengers side. I have removed all the vinyle mats (front & rear). The question is how do I get the bad smell out of the underlay. It is now dry but still smells. Also any ideas on how the
water got in I will check the usaul things air con drain and radio antenna
Reply By: Member Eric - Sunday, Mar 21, 2004 at 23:11
go to the
supermarket and get your hands on some fabreeze , unscreew the spray top and pore some on the underlay , works wonders . It was the only thing that got that terrible smell when your daughter gets sick lol
51330
Follow Up By: Lachy - Sunday, Mar 21, 2004 at 23:17
Thanks I will give it ago
313046
Follow Up By: desray - Monday, Mar 22, 2004 at 00:02
I have tryed the freebreeze for a smell in the car before,, I reckon the car smells worse after. I have half a bottle Free if anyone wants it. All in the nose I suppose lol
313049
Follow Up By: Member Eric - Monday, Mar 22, 2004 at 08:28
thats weired , I found it odourless lol , maby wife swapped the bottles on ya lol
313060
Reply By: Rojac - Sunday, Mar 21, 2004 at 23:17
new underlay
51332
Reply By: donk - Sunday, Mar 21, 2004 at 23:40
On a 100 Series the aircond evaporator is installed in the dash behind the glovebox by removing a cover (approx 8 inches high be 4 inches wide) that is held in by about 8 self tappers
Somes times when you reinstall the cover the gasket on the cover does not seal or is damaged & you will get
water from the aircond leaking on the lh front floor (common on a 100 series & normally a fitting problem)
The first thing i would do is to check the drain hose is not blocked (look for
water dripping from it with the aircond running) & if is ok than check (remove the glovebox) if there is
water dripping from this cover
The gasket was not available as a seperate part but if it is damaged you can us a sealant or cut a replacment from foam (if vehicle is still under warranty take it to a dealer to fix problem )
As far as the smell from the underlay ,normally you would remove the carpet & underlay & air it out until dry or replace the underlay (a motor trimmer should be able to supply this)
If it is not coming from the aircond check all firewall & floor grommets & run a hose over all the seams & around the windscreen & look for any
sign of leakage
Regards Don
51336
Follow Up By: Member - Bob - Monday, Mar 22, 2004 at 08:17
Is it possible for
water to enter vehicle from the roof rack slots? I can hear
water inside vthe A pillar after rain.
313059
Follow Up By: Member Eric - Monday, Mar 22, 2004 at 08:30
does your car have a sunroof ?
water runs through channels in you pillars if you do
313061
Follow Up By: Member - Bob - Monday, Mar 22, 2004 at 08:46
Yes I do. Does that mean I can stop having night mares about the A pillars rusting through?
313065
Follow Up By: Member Eric - Monday, Mar 22, 2004 at 17:46
yes mate , they have plastic tubed inserted in there , if the tube has come off the frame , then thats another issue lol
313152
Reply By: Member - Penguin (NSW) - Monday, Mar 22, 2004 at 09:41
I had the same problem on my 80 series and found a small leak at the bottom corner of the windscreen. Does it happen the morning after a good night's rain?
51360
Reply By: Truckster (Vic) - Monday, Mar 22, 2004 at 12:06
"I have had a bad oudour in my LC100"
*BITING TOUNGE*
51376
Follow Up By: johnsie - Monday, Mar 22, 2004 at 14:08
charcoal tablets maybe heh heh
313107
Reply By: Member - Don (QLD) - Monday, Mar 22, 2004 at 13:54
You can try some stuff called nilodour you should be able to pick it up at any
supermarket.this is the stuff they use in planes, so I have been told by a mate
51401
Reply By: donk - Monday, Mar 22, 2004 at 18:17
On a 100 Series the original bolts that hold the factory saddles on to the roof in the roof rack mounting positions have a thread sealant on them when installed in the factory
If you remove & replace these bolts(with the original ones or others) & dont apply sealant to the threads you may get
water leaking past them
Regards Don
51442
