How much oil 2001 GU 3lt
Submitted: Tuesday, Mar 23, 2004 at 00:46
RLNOMAD
OK, manual says that with a new filter the oil needed is 8.2Lts , when you dip it after filling with that much it hardly even shows on the dipstick...anyone got the answer...
Reply By: desray - Tuesday, Mar 23, 2004 at 01:49
Get a longer dipstick.. Sorry only joking. Does the oil take a long time to run down to the bottom / sump ?
51514
Reply By: Redjack - Tuesday, Mar 23, 2004 at 02:49
Didn't the GU 3lt have a recall to have it's sump capacity increased, by fitting a shorter dipstick. Maybe the owners manual hadn't been corrected.
51516
Follow Up By: Member - Jeff M (WA) - Tuesday, Mar 23, 2004 at 15:46
Sump level was increased from 6.5 to 8.5 in the 3L.
313316
Reply By: srowlandson - Tuesday, Mar 23, 2004 at 08:11
this recall affected only Prior to Nov 2000
I'd leave it overnight and see the next day. It can take a while for the oil to settle.
Steve
51522
Reply By: Glenn D - Tuesday, Mar 23, 2004 at 11:36
My GU takes 10 lts with a filter change. Watch also rear diff figures,a real bummer when you have just drained 5.4 lts out and it only says you need 2 lts . It was a nice walk to the
shop ,I guess thats what you get for being a tight arse and buying the Gregorys one instead of the factory one.
51553
Reply By: Davoe - Tuesday, Mar 23, 2004 at 13:48
I have a 'yota and also have found discrepencies in oil levels (all) and coolant - dont worry bout it just fill it up
51569
Reply By: Member -Bob & Lex (Sydney) - Tuesday, Mar 23, 2004 at 16:12
Mine varies to sometimes upto 9 ltrs.
51587
