80 Sereis squeak
Submitted: Wednesday, Mar 24, 2004 at 12:53
Justin
Just noticed it yesterday, a very noisy squeak coming from somewhere underneath, probably around the driveline. When in 1st 2nd and 3rd it goes sqeak....sqeak......sqeak, getting faster and louder the faster you go. When changing gears it dissapears and it appears only under load - so if rolling in gear there is no noise. Any ideas???????
Reply By: Pesty - Wednesday, Mar 24, 2004 at 13:00
Justin,
Sounds like a dry ( stuffed) uni joint.
Cheers Steve
51746
Follow Up By: Justin - Wednesday, Mar 24, 2004 at 13:13
Thanks Steve, thought that may of been the case. Do you know whats involved in fixing it? And what sort of costs?
313493
Follow Up By: Pesty - Wednesday, Mar 24, 2004 at 13:17
Are you able to do normal mechanical work? if not you will need to get your mechanic to do it. Joints are about $50 each, i advise to do both joints while its off if they have done similar amounts of work.
Steve
313494
Follow Up By: Wayne (NSW) - Wednesday, Mar 24, 2004 at 13:40
Justin,
If your 80 Series is a GXL, costant 4WD do all four uni joints.
I will be doing
mine soon as I have some big trips comming up.
Wayne
313495
Follow Up By: Justin - Wednesday, Mar 24, 2004 at 13:51
Wayne,
Its a STD 1HZ 1997
313497
Reply By: Roachie - Wednesday, Mar 24, 2004 at 15:23
It's a toyota......it's supposed to squeak isn't it Pesty??????
LOLOLOLOL
Roachie
51773
Follow Up By: Wayne (NSW) - Wednesday, Mar 24, 2004 at 15:41
Roachie,
May be there is a Nissan under the Cruiser that is making the squeak.
Wayne
313530
Follow Up By: Pesty - Wednesday, Mar 24, 2004 at 17:02
Roachie,
The squeeky wheel makes the most noise and requires the extra attention of special CRUISER OIL!!!!!!!!!!!!!!!!!!!
You wont win, Wayne Knows his stuff
313541
Follow Up By: Roachie - Wednesday, Mar 24, 2004 at 17:43
Okay,
You blokes out number me, so I'll crawl back in my hole and disappear.
Hey Pesty, did you get your belly
tank fitted yet?
Roachie
313547
Reply By: Davoe - Wednesday, Mar 24, 2004 at 17:00
Had the same thing when out bush other day traced it to a piece of dry wood stuck underneath rubbing on the front tailshaft sqeek sqeek
51795
