towing capacity of landcruiser 60 series
Submitted: Saturday, Mar 27, 2004 at 18:24
ThreadID: 11605 Views:23400 Replies:4 FollowUps:0
I have been trying to find out the towing capacity and ball weights for our 60 series wagon, didn't think it would be that hard but everyone down to some towbar boys have varying opinions. Generally they seem to agree at about 2500kgs but ball weights from 90 to 250kg.
any help would be appreciated.
whale
Reply By: Peter 2 - Saturday, Mar 27, 2004 at 19:30
I just had alook on a 1987 60 series brochure I have and the max tow weight without brakes is 750kg's and with brakes is 2500kg's "subject to state regulations and towbar design".
There is no weight on towball figure given.
I would have a sticky at a ARb or genuine Toyota towbar fitted to a vehicle, the capacity weights "should" be attached to a plate on the bar.
Interestingly the GVM of a 60 series is given as 2810kgs, I'll bet there are a few that exceed that with accessories never mind the load.
AnswerID: 52210
Reply By: Member - DOZER- Sunday, Mar 28, 2004 at 09:30
As stated...lol.....different states have different laws on towing. In NSW, you can not tow more than 1.5 times the GVM of the vehicle.(hope i got that right) The 60 GVM is about 2700, but the towbar is only rated to 2500, so that is the limit.
As a general rule, anything above 90kg ball weight is ok, the towbar recommends 150 max on mine, if you run less, the trailer can cause stabilty problems.
If you run more, you should use towing aids to keep braking in check, as the more ball weight on the back, the less weight on the steering (and braking) axle.
(towed a van round oz)
AnswerID: 52259
Reply By: Pesty - Sunday, Mar 28, 2004 at 21:05
Whale,
My 89 model has a 2500kg towbar and was told by towbar specialist that supplied and fitted it 2 years ago that ball weight is 10% so 250kg Am in S.A. if this makes a difference. Hope this helps
Cheers Steve
AnswerID: 52326
Reply By: whale - Monday, Mar 29, 2004 at 20:51
Thanks to all who replied with info. I tried a toyota dealer who told me to contact toyota. so off went the email only to be advised to contact a toyota dealer, now thats customer service.
So thanks again and with a bit of luck we will be on the road late this year on a aussie adventure.
happy offroading and just cruisin
Whale
AnswerID: 52482
