jackaroo lift
Submitted: Wednesday, Mar 31, 2004 at 09:20
ThreadID: 11691 Views:3090 Replies:6 FollowUps:2
Any jack owners out there who have had their jacks lifted? Can you tell me what you got & what were your results/opinions of the ride & lift.
I've just got one & I am scratching my head as to where the lift is? The ride is good but I was hoping to get a lift.
Jackablue
Reply By: Member - Wim (Bris) - Wednesday, Mar 31, 2004 at 09:59
Jackablue
Had my jack lifted by the local ARB people. They supplied a report on ride high before and after lift. I think 20mm front 25mm rear or there abouts. Ride is a lot better. I understand like most things with a jack, there is limmited adjustment available. My main concern was with the weight I carry & effects on suspension.
Good people to deal with & happy with the result.
Camper setup
July 2012 - Hay River & Binns track
VKS 737 Mobile 0091
Selcall 0091
AnswerID: 52619
Follow Up By: jackablue - Wednesday, Mar 31, 2004 at 10:25
My measurements show about 10mm to 15 mm unladen. When laden probably worst than original. Looks lower, haven't actually measured it because I never measured it laden with original springs. I have one of those static straps on the back that just touches the ground when laden. Laden with the new springs it is well on the ground!
This setup was to help me when laden & towing, don't see how?
What shocks & type of springs did you get?
FollowupID: 314468
Follow Up By: Member - Wim (Bris) - Wednesday, Mar 31, 2004 at 13:25
jackablue
OME shocks & springs.
Camper setup
VKS 737 Mobile 0091
Selcall 0091
FollowupID: 314496
Reply By: Robert - Wednesday, Mar 31, 2004 at 11:29
Jackablue
Installed Pedders coils in rear which gave 50mm lift unladen and wound up torsion bars about 30 mm in front. Rancho adjustable shocks all round.
When loaded rear is about 25mm over standard and I adjust the shocks to suit the load and ride, Very happy with result.
Robert
AnswerID: 52630
Reply By: Tim - Wednesday, Mar 31, 2004 at 17:25
Yeah mine came up about 2" at the back and 1.5" at the front, had RS5000s and lovells springs. Not sure about the laidn height but it doesn't hit the bump stops anymore so its done something.
AnswerID: 52674
Reply By: Terryfied - Wednesday, Mar 31, 2004 at 21:29
Jackablue,had ORE in Myaree (W.A) fit King springs coils with a 40mm lift to the rear,This was mainly to compensate for larger fuel tank,drawers and equipment.
Have wound up the the front 25mm and put on overlander h/d shocks all round,I also put on 235/85/16 toyo tyres .The tyres have have added a further 25mm ground clearance which is very handy on the jackaroo.
Terry
AnswerID: 52726
Reply By: Billy - Thursday, Apr 01, 2004 at 06:58
Jacka,
Another alternative if you have variable loads is to go with Polyairs in the rear. The Jack I had did a lot of work fully loaded on them and I found them terriffic. I just wound the standard bars up at the front and the bags at the back gave the standard springs a sizeable lift (probably about 30mm) when they were pumped up.
As for shocks, the IFS is really hard on them, the back not so bad. I'd spend the dough on Bilstien for the front and put some OME's or TJM XGS on the back.
Regds
Bill
AnswerID: 52749
Reply By: jackablue - Tuesday, Apr 06, 2004 at 13:42
I took the Jack back about the ride height to try some other springs. Well I got the jack back yesterday & it sits a little higher now. It now sits about 30-35mm higher & thats with both tanks full (145ltrs). The ride is still fantastic. The true test will be when I load it up again, probably this easter weekend. The springs I had first were the OME 919. After questioning the ride height OME recommended the OME 929 (taller) which is for models after 2001. So far much happier.
Thanks for all your imput
AnswerID: 53386
