Rivnuts
Submitted: Saturday, Apr 25, 2015 at 13:31
Gone Bush (WA)
Some time ago there was a discussion on blind nuts, or rivnuts as they are also called.
Here's a link if anyone is interested in getting a bunch of them.
Rivnut kit
Reply By: Frank P (NSW) - Saturday, Apr 25, 2015 at 16:42
Thank you GB, a great price.
My son and I will be buying one of those.
552917
Reply By: Stephen_L - Saturday, Apr 25, 2015 at 18:37
I have one of these exact kits and it has served me very
well and has been used many times.
This was the sort of tool I bought for a specific job but thought might me handy to have every now and then. Turns out I seem to keep finding uses for it, and have used it more on mates cars than
mine.
Recently I borrowed a mates rivnut tool and the difference was chalk and cheese.
His version was a sort of ratcheting type. Far less effort required to insert the rivnut and much more control over how much you compress the insert. However his cost much more (as is always the case).
This type
A great tool to have.
552922
Reply By: Peter_n_Margaret - Saturday, Apr 25, 2015 at 21:45
The OKA has lots of 6mm rivnuts so I bought one of those
tools some years ago to replace failed nuts.
Couple of tips...
1. Filing a couple of 'nicks' in the hole with a small triangular file provides more anti spin resistance.
2. Nuts are also available in aluminium - useful for some jobs.
3. The OKA also has some BIG ones (12mm +) in the chassis. These are normally only set with a hydraulic tool, but if you give then a couple of tack welds around the head, they can then be pulled up using a bolt, flat washer and long handle on the spanner.
OKA196 Motorhome
552932
Reply By: Member - Alastair D (NSW) - Sunday, Apr 26, 2015 at 06:47
These things are also called Nutserts and I have used many over the years. Fasteners Galore who are based in Qld carry a big stock in all sizes in steel, Al, SS etc and sell at good prices in small and large quantities. I usually get next day delivery in
Sydney.
Fasteners Galore
No connection etc.... just a good source when you need nuts, bolts etc quickly.
552935
Reply By: AlbyNSW - Sunday, Apr 26, 2015 at 09:02
I have what looks to be the same tool
It works fine but if you are wanting to set a lot of M8 plus size ones a bigger tool would be better
That tool is fine though and happy with it
552941
Reply By: Rangiephil - Sunday, Apr 26, 2015 at 11:48
I bought a similar if not same tool from the USA several years ago.
The thing that has me beat is that although the rivnuts are all metric internal thread, the drill sizes required to fit them are imperial.
You can usually get a metric drill pretty close to what is required , but it is a very strange thing to do IMHO.
Regards Philip A
552950
