AnswerID: 53035 Submitted: Saturday, Apr 03, 2004 at 10:05
Jimmy
replied:
Hey Wizzard
If your vehicle does not have a permanent + wire to your stereo you can still use the unit only the time settings and station settings will be lost each time you turn off the ignition. Stereos have two + wires, one on all the time and one switched. On the back of your stereo it will tell you which colour to connect to the switched + and which to connect to the unswitched +. Just leave to non switched wire disconnected and taped off. Failing that run a wire from the fuse box to your stereo just make sure it is fused. There will most likely be a wire for an electric antenna, tape that off too.
I just bought a CD player from Super Cheap $49 if thats the same one as you bought, take it back straight away and buy a better one if the CD part is important to you. It is absolute crap!! The radio is pretty good which is all I really needed
Jim
Reply 2 of 3
