map scales
Submitted: Tuesday, May 21, 2002 at 00:00
ThreadID: 1180 Views:2277 Replies:6 FollowUps:4
Hi all, what is the best scale maps to get for a 4WD trip? I have a general book covering all roads and many 4WD tracks in Western Australia, but what scale maps should i get for specific areas???
Cheers in advance.
Reply By: Ed Bee - Wednesday, May 22, 2002 at 00:00
Jono, you will not find better coverage than the Hema series regardless of the scale; have a good one.
AnswerID: 3738
Reply By: Andrew O - Wednesday, May 22, 2002 at 00:00
Jono,
This is a horses for courses kind of thing, and it also depends on the terrain. I use the paper Hema maps, they are very good, but on the PC & GPS I use Auslig 1:250 000, and some 1:25 000. The problem with the 1:25000 is that you cross the in a 4WD to quickly, so whilst good for bushwalking, not so good in a car. I have used the 1:100 000 and I find this the best compromise on detail / size ... I'm now waiting for their release by AUSLIG on a few CD's then I'll be set.
AnswerID: 3740
Follow Up By: Darren - Wednesday, May 22, 2002 at 00:00
Andrew. Are Auslig going to issue 1:100000 on CDs?
FollowupID: 1579
Reply By: MikeS - Wednesday, May 22, 2002 at 00:00
Jono, as Andrew says, it depends on what information you want to get from the map. 1:25,000 topographic maps are great when you want to assess the type of terrain, i.e. steepness of tracks, water courses and possible bog-holes, vegetation (clearings, plantations, scrub). If your trip is only likely to cover a short distance, say less than 50k's a day over difficult terrain and it is important to know exactly where you are for navigation purposes, the smaller scale maps are better. Otherwise Hema maps are a good scale for touring over bigger distances. It all comes back to what sort of information you want from the map. You wouldn't use a world atlas to find a suburban street.
AnswerID: 3742
Had to cut short my previous reply, but the comment regarding use v scale is entirely correct. On my PC I also carry an Australian map at 1:2.5million, more general maps at about 1:1.5million, plus the Auslig CD's, so depeneding on the view I want, I just choose the appropriate map. All this is pretty easily accomplished on OziExplorer - a great bit of software.
It is my understanding that AUSLIG are looking to bring out 1:100K Cd's. These maps are already available from LPI in NSW, but they are bundled with the 1:25K maps and cost almost $1000 for all of NSW. Hopefully AUSLIG's pricing will be more user friendly!
AnswerID: 3744
Follow Up By: Colin Johnson - Wednesday, May 22, 2002 at 00:00
A series which can also be very helpful is 1:250 000 Geology maps. They are available usually from State Geol Surveys or AGSO/Geoscience Australia. A lot of remote area Auslig Topo maps are not updated but a more recent geology map can sometimes have more/better track data. The coloured Geology can be a confusing and sometimes helpful !
FollowupID: 1597
Reply By: ExplorOz Team - Michelle - Wednesday, May 22, 2002 at 00:00
Jono,everyone's advice is correct here although I will add that if you are generally touring and your interests are mainly finding access tracks, camp sites, points of interest, facilities, river crossing etc then Hema and Westprint maps are generally of appropriate scale for that kind of use with additional information printed on the map and a key on the map to identify various points of interest.
AnswerID: 3748
Follow Up By: Jono - Wednesday, May 22, 2002 at 00:00
Michelle,
Thanks for that, so do you think that for some general 4wd'ing and looking for access tracks and camping spots etc, it would be good enough to get the "Discover Australia by 4WD"? Also, how good is this book, specifically for WA, and is there a better alternative for WA?
FollowupID: 1583
Reply By: Michelle - ExplorOz - Wednesday, May 22, 2002 at 00:00
Jono - I actually would recommended Hema's 4WD Road Atlas. The Discover 4WD book contains good maps in between trek notes with the trek notes being the main feature. In comparison the Road Atlas is better than the maps in the book as they are clearer, larger and easier to carry. The trek notes you see in Discover by 4WD are all covered by ExplorOz anyway plus more so get the best of both worlds and print off our treks and opt for the atlas.Having said that, the Discover NP book is a fabulous compliment - I am particularly impressed by it.
AnswerID: 3754
Follow Up By: Jono - Friday, May 24, 2002 at 00:00
Thanks Michelle, i will look into the Hema 4WD Road Atlas, cheers.
And Thanks to everyone for you help on this one, much apprecialted. Jono.
FollowupID: 1613
